Old 11-07-2017, 11:58 AM   #1
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Best Track Times
Camaro6 Best Track Times List - Google Sheets
Best Track Lap Time:
Thank you Provoste for getting this started! This thread is intended to be fun & informative.
Please post using this format:
Track = VIR
Time = 2:01.88
Year/Model/Trim/Trans = '21 SS M6
Date = 9/3/23
Tires = OE SC3R
Mods = SRF, DS3.12, AWE, Rotofab
Entries must have some sort of timing verification; some examples are as follows:
Lap Timer Picture/Video, AIM, PDR, Catalyst, Apex Pro, Harry’s Lap Timer, etc.
*Raw video with no overlay will not be counted*
To view the list cleanly on a mobile device, download the Google Sheets app.
Google Play Link
App Store Link
FollowMyLine is offline   Reply With Quote
Old 11-07-2017, 12:00 PM   #2
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
I’ll start (I’m only listing my lap times on street tires for now):
Barber, 1:41.50, 2017 SS 1LE, 2/11/17, Stock Goodyear G3’s, DTC 60 Brake Pads, stock performance alignment -2.2 front, -1.6 rear, stock engine/trans/suspension.
PDR Video: https://youtu.be/fkT-0hLClrQ
Mid-Ohio Club Course, 1:39.59, 2017 SS 1LE, 7/7/17, Bridgestone RE71R (295 square), DTC 60 Brake Pads, Alignment mods (ground struts) -2.9 front, -1.8 rear, stock engine/trans/suspension.
PDR Video: https://youtu.be/9pdz3jOQ44o
National Corvette Museum Grand Full, 2:16.86, 2017 SS 1LE, 4/22/17, Bridgestone RE71R (295 square), DTC 60 Brake Pads, Alignment mods (ground struts) -2.9 front, -1.8 rear, stock engine/trans/suspension.
PDR Video (Best lap ends @ 6:56) : https://youtu.be/qirY-8y59sE
Putnam Park, 1:16.23, 2017 SS 1LE, 9/9/17, Bridgestone RE71R (295 square), DTC 60 Brake Pads, Alignment mods (ground struts) -2.9 front, -1.8 rear, stock engine/trans/suspension.
PDR Video: https://youtu.be/V7Tnw7e8PN0
Watkins Glen International, 2:11.28, 2017 SS 1LE, 5/28/17, Bridgestone RE71R (295 square), DTC 60 Brake Pads, Alignment mods (ground struts) -2.9 front, -1.8 rear, stock engine/trans/suspension.
PDR Video: https://youtu.be/7p0fmmEPkuI
Provoste is offline   Reply With Quote
Old 11-07-2017, 02:01 PM   #3
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Not my car but Randy Pobst in another SS 1LE on 100% OEM setup. He ran a 1:39.70 @ Charlotte Motor Speedway Roval Course. See 3:20 in video.
Old 11-07-2017, 02:52 PM   #4
JeromeS13
Drives: 2017 1SS/1LE
Streets of Willow, ’17 SS 1LE, 1:25.402, 2/25/17, OEM tires, Factory alignment, No mods, Video
Old 11-07-2017, 02:58 PM   #5
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Gingerman Raceway, 2017 1SS 1LE, 1:41.04, 4/15/17, Supercar 3's, stock suspension (-2.0° front and -1.5° rear), Power Stop Track Day pads. Video, lap ends at 13:01
Grattan Raceway Park, 2017 1SS 1LE, 1:26.37, 9/2/17, Supercar 3's, Moreno camber plates (-2.6° front and -1.7° rear), ST-43 pads. Video, lap ends at 12:36
Old 11-07-2017, 03:08 PM   #6
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
I'll play.
Ariozona Motorsports Park CCW, 2016 Camaro 2SS, 1:52.889, 10/29/17, crappy goodyear F1 Supercar runflats, BMR suspension/Moreno Motorsports Camber plates/19x10 Apex wheels/ST43 pads.
car 808 on here for time confirmation. Transponder timed. : https://racehero.io/events/nasa-az-arizona-motoroports-park-ccw/results/1073743347#show
Be Careful with Harry's. I've had it count my laps up to 3 seconds fast with a poor satellite signal if using the phones internal 1hz gps
Eric SS is offline   Reply With Quote
Old 11-07-2017, 03:30 PM   #7
Provoste
Provoste's Avatar
First group up on the list
Old 11-07-2017, 03:57 PM   #8
slick3
Drives: Garnet Red - 20 ZLE
Big Willow Raceway, 2017 1SS 1LE, 1:35:62, May 2017, Supercar 3's, Mods in Sig (LESS Cylinder heads and Wheel/Tire) (-2.2* Front - -1.5* Rear)
slick3 is offline   Reply With Quote
Old 11-08-2017, 01:15 AM   #9
SPORTBIKES
SPORTBIKES's Avatar
Drives: 1967 Firemaro / 2017 2SS
Here is my 2017 2SS - fresh Supercar 3s- Eibach pro springs
Race Chronos Pro keeping time using external 10MHz GPS.
Big Willow ambient temp 70degrees
1:35:3
Went Yesterday - November - had a fresh set of NT01s and for some reason I was sliding all over. Called Nitto from the track - lowered track pressure in tires to low 30s and gripped better, but still sliding through 2 where I was unable to exceed 85mph? Spoke to some pros that were there, they said the track has a bunch of rubber from some heavy use over the weekend? Hoping to see 1:34 soon.... with grip in 2 and bigger "balls" in 8.
Mike Dee
SoCal USA
2017 Camaro 2SS
2015 Corvette Z06/Z07
1975 Supercharged Corvette
1967 Firemaro Show Car - For Sale
SPORTBIKES is offline   Reply With Quote
Old 11-08-2017, 09:44 AM   #10
Yanbags
Yanbags's Avatar
Drives: '17 SS 1LE
Love the format! Only 1 track day with this car so far :( will have more next season.
Watkins Glen International, '17 SS 1LE, 2:11.21, 8/27/2017, OE Goodyears, Alignment
PDR Video (Lap starts @ 21:32 marker):
Yanbags is offline   Reply With Quote
Old 11-08-2017, 10:36 AM   #11
Eric SS
#becauseracecar
Eric SS's Avatar
Just an FYI, Arizona Motorsports Park runs but CW and CCW so you may want to add to mine that it was CCW as the track is a few seconds different each way. Thanks and I love this idea for a thread. It should be stickied.
Old 11-08-2017, 10:37 AM   #12
Lugnutty
Lugnutty's Avatar
Drives: 2022 2SS
I've only had the car out to Blackhawk so far.
Blackhawk Farms Raceway, '18 SS 1LE, 1:19.99, 9/30/2017, OE Goodyears, all stock except for ST-43 pads F+R
Lugnutty is offline   Reply With Quote
Old 11-08-2017, 11:46 AM   #13
slick3
MODS PLEASE STICKY!!!
Old 11-08-2017, 11:55 AM   #14
Mr. Meh
Drives: Sold
Track = Autobahn Country Club - Full Course - Joliet, IL
Camaro Model = 2017 Camaro ZL1, A10
Elapsed Time = 2:54.80
Date = Aug 7, 2017
Tires = OE GY nonRFT
Mods = Valovine SynPower MST 5W/40 motor oil, Motul RBF600. Otherwise stock.
Mr. Meh is offline   Reply With Quote
