Old 02-06-2017, 10:20 PM   #1
Canadian ZL1
Canadian ZL1's Avatar
Drives: 2017 ZL1, 1995 Trans Am
Clearance Front Splitter (Front and Side)?
Guys,
For those of you who are lucky enough to have your ZL1's I was hoping someone might be kind enough to take a tape measure and tell me the distance from the front black splitter to the payment and from the side as well.
The reason I am wanting to know this is I have a slanted driveway and I am very concerned about it the car rubbing and or scratching the payment as I drive into my driveway. I need to prepare now and need these measurements.
Thanks in advance.
_____________________
'17 ZL1 HBM|A10|NAV|PDR|CFW Hood|Sunroof
Canadian ZL1 is offline   Reply With Quote
Old 02-07-2017, 12:46 AM   #2
datboi448
datboi448's Avatar
Drives: 2013 2LT RS, 2017 ZL1
I would also like to know how people are faring in the concrete jungles. I don't even know if I can make it out of my garage at work without looking like cammisa at the beginning of the M4 GTS ignition episode
datboi448 is offline   Reply With Quote
Old 02-07-2017, 10:22 AM   #3
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
C&D mag says 4"
I scrap a little ever time I leave the house....dont let that stop you from enjoying a great car.
Get some of these from ZL1addons.com...splitter guard washers.
https://zl1addons.com/collections/splitterguard-washers
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 02-07-2017, 11:28 AM   #4
Canadian ZL1
Originally Posted by KaBoom1701 View Post
C&D mag says 4"
Thanks very much. I did not know these existed. I am guessing the $42 investment is worth it. Not sure exactly how they work but assuming they do the job.
Old 02-07-2017, 12:10 PM   #5
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
you will most likely be perfectly fine as long as you come in and out on a angle. 4 inches is plenty. my evo x was definitely lower than 4 inches and never had a problem with my inclined driveway or entrance ramps to places.
Evolvedx27 is offline   Reply With Quote
Old 02-07-2017, 12:25 PM   #6
Canadian ZL1
Yes that is what I currently do (come in and out on an angle) with my Acura TL which has the A-Spec package on it. Surprisingly it is 6" off the ground where the Zl1 is 4"...yikes. That 2" is going to make a difference unfortunately. My TL just barley clears so the Zl1 will most likely scrape. I am guessing the splitter washers will help a lot.
Old 02-22-2017, 10:23 AM   #7
Sub
Sub's Avatar
Drives: 2017 ZL1
Has anyone "amazon'ed" those washers? $56 for some plastic pieces is crazy, I'm sure they must exist for some other industry application.
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
Old 02-22-2017, 10:29 AM   #8
67Builder
White knuckled & smiling
67Builder's Avatar
Drives: '17 ZL1 AKA Perfection!
They're actually made of steel, and saved my 1LE splitter several times. 50 bucks for some little pieces is crazy till you think about how expensive that splitter is to repair/replace.
2017 ZL1 A10 CFHood PDR NAV NFG - Order # VCSDRJ
TPW -
3/6/2017 VIN - 1G1FK1R62H0192950
6000 - 04/05/2017 - Delivered!
67Builder is offline   Reply With Quote
Old 02-22-2017, 12:23 PM   #9
DDP98
DDP98's Avatar
Drives: 2017 ZL1
You should not have a problem with the splitter itself unless you go head on into a steep entry/exit without caution, but rather the guard below it. There is a rubber guard right below the splitter and that's what scrapes, along with the plastic cover underneath the car that some have already mentioned.
I have a bad driveway entrance for any car that's not an SUV. It kinda sucks but with a board down, it will scrape slightly if at all. I'm still trying to find a viable solution without having to have the entrance re-paved or have the angle reduced with asphalt.
I would definitely get the splitter covered with PPF, along with the rocker panels. They will get beat up from road debris and chip the paint. I have my entire front end, rockers and lower quarter panels covered in XPel film. Worth the investment in my opinion.
One thing to consider: speak with the installer about how they tuck the film underneath the splitter and rockers. Because the underside of these parts will take so much abuse from road debris, it will begin to peel up. It's worth while to ask the installer about tucking the film just slightly under these parts.
Hope that makes sense.
12/06/2016 - 1100
12/26/2016 - 2000
12/27/2016 - 3000
01/16/2017 - TPW
1/18/2017 - 4200
1/302017 - Delivered
DDP98 is offline   Reply With Quote
