Old 01-02-2017, 05:55 PM   #1
gosutag
Left Lane Enforcer
Drives: '18 ZL1 1LE.
Removing front SS badge on Grille.
How do I do this? Thank you.
Current Cars:
2018 Camaro ZL1 1LE
2012 Ford Focus SE
1994 Evo II
Previous Cars:
2017 Camaro SS
2014 Chevy Malibu LTZ
gosutag is offline   Reply With Quote
Old 01-02-2017, 07:28 PM   #2
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
hair dryer or heat gun and pull
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
Darth Martel is offline   Reply With Quote
Old 01-02-2017, 07:37 PM   #3
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Whatever you do do not use 3m adhesive remover, it will turn your grill gray. This was my first time ever having a problem with this product, i used it to remove rear ss badge and it just falls off
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 01-02-2017, 07:51 PM   #4
Racerman27410
Racerman27410's Avatar
Drives: 2016 SS 2SS
the entire block the emblem is affixed to comes off the grill.... there is just a plastic piece on the backside of the grill that locks it on... way easier to remove than the bow tie
Racerman27410 is offline   Reply With Quote
Old 01-03-2017, 01:38 PM   #5
ToadMcFrog
Drives: '17 2SS
I just did this to replace my SS emblems with some painted by River City Creations. I think the easiest way to get the block off is to reach under the emblem and pull down and slightly forward on the back edge to release the tabs on the "lock" piece from the back side.
ToadMcFrog is offline   Reply With Quote
Old 01-03-2017, 03:01 PM   #6
JKLNHYD
Defending the Nation...
JKLNHYD's Avatar
Drives: '16 Summit White 2SS, A8, Sunroof
Is the bowtie attached in the same type of manner? ...with a block that comes off the front grill completely?
'16 2SS, A8, Sunroof, non-NPP
"SURSUM AB ORDINE"
JKLNHYD is offline   Reply With Quote
Old 01-03-2017, 04:08 PM   #7
Racerman27410
Drives: 2016 SS 2SS
No
Old 01-03-2017, 06:23 PM   #8
Sub
Sub's Avatar
Drives: 2017 ZL1
I just installed one on me sema grille. There are two very thin plastic alignment pegs in the back, one is much longer than the other. It has full 3m vhb adhesive on the back.
I'd probably try the fishing line method - worm it under the adhesive a bit then try and pull.. if that doesnt work, continue sawing the line under the emblem to cut the adhesive.
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
Old 01-07-2017, 11:01 PM   #9
hzisfrom1994
ZYJ
hzisfrom1994's Avatar
Drives: 2017 1SS Camaro/6 speed
I just put my hands in behind the badge, inside the grille, work/play around it and it pop right out. Hope it helps lol. Took less than 1 minutes without knowing how it was attached by just playing around.
hzisfrom1994 is offline   Reply With Quote
Old 01-08-2017, 06:30 PM   #10
aa406079
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6
what does the front grill look like when you remove both the bowtie and the backing?
aa406079 is offline   Reply With Quote
Old 01-10-2017, 08:45 AM   #11
Camaro36
Drives: Camaro 2SS
Camaro36 is offline   Reply With Quote
Old 01-10-2017, 11:24 AM   #12
jp9109
Clay Sculptor at GM
jp9109's Avatar
Drives: 2016 Camaro 2SS, M6, MRC, NPP
Unfortunately, the bowtie mount is molded into the upper grille texture so only the bowtie is removable unlike the ss badge on the lower grille. You can see on my car I have the bowtie removed to modify it. Post #1318 in the hyper blue thread, you posted a reply to it lol.
jp9109 is offline   Reply With Quote
Old 07-19-2017, 11:23 AM   #13
MelloYellow
MelloYellow's Avatar
Drives: 2016 Camaro SS Convertible
Can the fishing line/dental floss method be used to take the coloured "facing" from the SS emblem on the grille? I want to just replace with a colour matching "SS" logo. Anybody have any input? Thanks!
MelloYellow is offline   Reply With Quote
Old 07-19-2017, 11:50 AM   #14
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
You will paint or wrap right over the red, no problem.
