#1 | ||
![]() ![]() ![]() ![]() ![]() Drives: Gen 6 Camaro RS Join Date: Dec 2015
Camaro ZL1 Will Hit 60 mph in First Gear
Could mean mid-3 second 0-60 runs.
Per Road and Track: Quote:
![]() ![]() Drives: 1970-1/2 Z-28, 2017 ZL1 Join Date: Sep 2012
0-60 without having to shift....oh my.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Car Join Date: Jun 2010
Either raised the RPM fuel cutoff, or we're looking at 2.39:1 or higher 1st gear then, to hit 60MPH in 1st.
Been talked about a bit here in other threads. |
Moderator.ca
If I remember correctly, Al said that they found they were extremely close to hitting 60 in 1st while the car was under development, so they finagled things a bit (99% sure it was the fuel cutoff being raised a hair, instead of a gearing change) and now it does.
Mostly its going to help with 'hero runs' and magazine testing, as most people will be shifting before that when at the drag strip
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
![]() Drives: truck Join Date: Aug 2015
cool
Petro-sexual
Didn't he say 3.73s for A10s and M6s? If so, I'm with 'Wiki - probably a mid-2' ratio for first gear to wind out to 6500 past 60. That should keep it within a squeak of the A10s 0-60 it seems to me. And I'm not complaining for stock tires on an unprep'd surface. That's DANG good.
#7 | |
My video posted in my other thread actually shows him talk about this 0-60. Not sure why the OP tags my part one video as it doesnt have him say this. I can't remember if he mentions the gearing.
1967 Base 327 - numbers matching 10C car - (TruBlu - Marina Blue inside and out, still own)
1986 Base V6 - 1987 (Calif.) RS - 1995 Base V6 (all sold) 2017 2SS “Tribute FIFTY” in Blue (HBM, 56R, 5VM, MX0, F55, NPP, RN2, RZ9, S0O, S0V, IO6 Tribute RPO: BR9, FTJ, 56Y, CJL)#teamBeckyD |
#8 | |
Petro-sexual
OK. Well - it's right there. I must've thought I heard something else about the 3.73s, but the M6s are getting it, so I didn't screw that up too much.
#9 |
Petro-sexual
I think C6 ZR1s got a low 1st gear, like 2.40 or something, in order to run to 60 without shifting... Those were running 3.42s, though I think, but on shorter 26-inch tires, whereas I imagine ZL1 will be running a few inches bigger like last generation.
#10 |
![]() Drives: Camaro ss Join Date: Nov 2011
60 mph
I think the ratio of the differential can be from 3.31 to run 60 miles without making the switch to second gear
#11 |
This thread has been covering this information
http://www.camaro6.com/forums/showthread.php?t=462979 |
