Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 10-08-2009, 06:33 AM   #1
Tanner
Tanner's Avatar
Drives: 2010 Camaro 2SS/RS
Rough Engine Start After Tune?
There are people on here that know more than most out there so here's my issue. I had ar long tube headers with high flow cats put on Monday and a tune right afterwards. When the tuner was done the engine started rough. They pulled some fuses even disconnected the battery and connected it again. The engine still started rough. They said it will be rough for awhile but will come out of it. Now two days later the check engine light came on.
Will the engine start issue straighten itself out? Did the start issue cause the check engine light or did the tuner not disable the cat efficiency codes which will cause the check engine light to come on? Should I bring it back to the tuner right away or wait for a few more days?
Here is a video of the rough engine start. I put Borla S Type mufflers on and a Roto-Fab CAI also. It sounds great, but I don't want the rough start or check engine light to cause more issues.
2SS/RS Victory Red / painted White Rally Stripes - 6 Speed Automatic with Tap Shifter
Sands - Surprise
Tanner is offline   Reply With Quote
Old 10-08-2009, 07:03 AM   #2
jbsrace1
jbsrace1's Avatar
Drives: 2010 2ss
You need to disconnect the battery and leave it disconnected for at least 5 min.
The fuel pump module did not reset after the tune. It has to be disconnected long enough for the capacitors to bleed down to allow it to reset.
jbsrace1 is offline   Reply With Quote
Old 10-08-2009, 10:21 AM   #3
mark_p
Drives: 2010 2SSRS m6
Take it to another tuner. your tuner is an idiot. It should NEVER do this. He probably did not even delete the rear two 02 sensors either. Mine is programmed to take about 1.5s to start but thtat is on purppose. He should never tell you that it is going to work itseld out. That is a cop out for I don't know what I'm doing. Yours sounds sick.
mark_p is offline   Reply With Quote
Old 10-08-2009, 11:00 AM   #4
D1BADZ
hmmmmm
D1BADZ's Avatar
Drives: 2010 IOM in-n-out 2SS
Word, that should never happen, and a good tuner would never let a car leave there shop like that
"Responsibility is a Heavy Responsibilty" (Cheech)
D1BADZ is offline   Reply With Quote
Old 10-08-2009, 11:00 AM   #5
Bmble_B
Bmble_B's Avatar
Drives: 2SS Rally Yellow LS3/Maggie
Remove the negative battery cable from the battery. Touch the negative cable to the positive cable for a couple of seconds. This discharges all memory and capacitors within every module on the vehicle. No need to take negative cable off and leave it off for any amount of time. This also resets fuel trims quickly.
Bmble_B is offline   Reply With Quote
Old 10-08-2009, 11:31 AM   #6
Tanner
Tanner's Avatar
All I have to say is "You gotta LOVE this web site and its members"!!!!!!!!!! She starts right away now. The check engine light is off now too.
I disconnected the negative battery cable and left it off for 5 minutes, then touched the negative to the positive terminal for 2 seconds using another wire as the negative cable won't reach over there.
THANKS FOR THE HELP GUYS!!!!!!!!!!! You're the best. I don't like when she's sick, I was worried about her and you helped...big time.
I'll post a video of how she starts now. She sounds fantastic!
Sands - Surprise
Old 10-08-2009, 11:41 AM   #7
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
Glad to hear Camaro5 strikes again with great advice.
Scott@Bjorn3D is offline   Reply With Quote
Old 10-08-2009, 12:18 PM   #8
jbsrace1
jbsrace1's Avatar
Drives: 2010 2ss
I do not ever like to talk bad about another shop but it should have never went out the door in that condition.
Glad you got it straightened out
Old 10-08-2009, 12:19 PM   #9
kelley@vectormotorsports
Drives: 2009 Pontiac G8 GT
That's how we do it.
kelley@vectormotorsports is offline   Reply With Quote
Old 10-08-2009, 12:25 PM   #10
2Tightwads
Drives: 2002 LS1 swapped into a 1994 Z
Yup read about this on HpTuners.com months ago. Jbsrace1: Post up your shops name for this solution. You deserve some props for being a reputable place.
2Tightwads is offline   Reply With Quote
Texas Speed & Performance Fall Engine Sale Trevor @ Texas Speed V8 Bolt-Ons & Tunes 2 12-08-2009 10:19 AM
ill start, here is my tune camaro1 Tuning / Diagnostics -- engine and transmission 9 08-01-2009 08:30 PM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 04:35 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 10:06 AM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 04:00 PM
