06-01-2019, 10:51 AM | #1 |
Drives: 2019 ZL1/1LE, 2015 Z/28, 2016 Z06 Join Date: Oct 2008
1LE wheels on a base ZL1
Is there any issues, with 1LE on a base ZL1? I really want the wider tires in the rear.. and if anyone has a set Im looking to buy a set..I had 325 30 19 on my 2015 Z28 and loved the look...
06-03-2019, 09:17 AM | #2 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
There was a post on the forum that indicated that that the 1LE will not fit on the base ZL-1, because of the clearance issue associated to the mag ride shocks. A solution might be a spacer on the wheel! Do a search on the posts, I am sure you will be able to find it.
06-03-2019, 11:17 AM | #3 |
Drives: 2018 ZL1 1998 SS 1992 Typhoon Join Date: Nov 2015
You will be fine on the street alignment. If you want to use the track alignment, guys are using the spacer. I'm running OEM z28 which are the same spec up front with no spacer.
06-04-2019, 12:45 PM | #4 |
Thanks guys, I'm going to order some BC Forged
06-05-2019, 05:50 AM | #5 | |
Drives: 90 vette BBC-10 ZR1-18 ZL1 Join Date: Mar 2011
Here's a video of a ZL1 with 1le wheels.
https://www.facebook.com/3cracing2/
Miss you Natasha. Current garage: 2018 ZL1 2016 SL400 2014 Sonic Turbo 2011 GMC 3500HD | Dually | Duramax | Extended Cab 2010 ZR1 1990 Corvette. 555CI EFI | N/A | 750 rwhp | Jerico road race 5 speed | 203+ mph standing mile | mid 9's in 1/4 Previous Sports cars: 2009 Corvette Z06 2006 Corvette Z06 2005 Corvette 1995 NSX-T 1993 NSX 1991 Corvette. Lingenfelter 1987 Corvette. Callaway Junk 1986 944 Turbo 1985 Corvette 1984 Corvette 1981 Corvette |
06-05-2019, 06:06 AM | #6 |
Thank you Al Oppenheiser!
Here's the thread for fitting ZL1-1LE wheels on the ZL1:
https://www.camaro6.com/forums/showthread.php?t=500284 And here's the thread for modding the strut to get more camber out of a 1LE wheel setup... which shows a little more detail about grinding the strut. Doing a strut grind without enlarging the bolt holes will work for clearancing the wheels: https://www.camaro6.com/forums/showthread.php?t=526353 You'll probably want to run some rock guards... |
06-05-2019, 09:49 PM | #7 |
I called RK today, BC Forged wheels are on order
06-06-2019, 03:25 PM | #8 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
They fit just fine. I have a set. With 100% OEM alignment, I had about 5mm of clearance to the strut, a grinder took care of that small issue but no other changes were needed.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
06-06-2019, 08:18 PM | #9 |
C.O.T.W. 10-27-2014
Bc forged
Zl1 1le factory specs and tire sizes on zl1. I'm on coilovers and didnt need spacers. Not sure about the factory shocks.
06-06-2019, 09:06 PM | #10 |
I'm going to go out on a limb and say those wheels aren't 12" wide on the rear like the 1LE
06-06-2019, 09:27 PM | #11 |
I didn't grind anything but placed a 5mm spacer up front just to make certain with track camber nothing would hit. Rear fits perfectly...no spacer. 2018 ZLE wheels.
06-07-2019, 02:20 PM | #12 |
C.O.T.W. 10-27-2014
unless factory specs are not 12 inch
19x11 front and 19x12 rears
06-07-2019, 02:34 PM | #13 |
