Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 06-09-2010, 05:51 PM   #1
GFORCE1320
Drives: 05 GTO
New product from Gforce Engineering - Billet pinion yokes
Gforce Engineering is proud to announce that we now have our billet pinion yokes available for the Camaro and G8 rears.
The new pinion yokes are machined from billet 4340 and use the big 1350 series u-joints.
This is the same billet pinion yoke that we will supply with our Camaro and G8 driveshafts.
The Camaro and G8 pinion yokes are interchangable.
With our billet pinion yokes, swapping to a race transmission like a TH400 or 4L80 is very easy.
Just bolt on our billet pinion yoke and have your favorite driveshaft builder make you a driveshaft or give us a call as we can also supply your driveshaft.
Thanks
Chris @ Gforce
GFORCE1320 is offline   Reply With Quote
Old 06-09-2010, 06:15 PM   #2
Ghost-Rider
Ghost-Rider's Avatar
Drives: SW 2SS/RS
Wow! Those look nice - are they heat treated? What kind of coating/plating are on those things?
Ghost-Rider is offline   Reply With Quote
Old 06-09-2010, 06:18 PM   #3
GFORCE1320
Drives: 05 GTO
Oh yea, heat treated to 48 on the Rockwell C-Hardness scale in our special vacuum fired oven process
We normally coat all our parts in an aerospace process called black e-coat but that line went down so we went with our yellow zinc back up coating process.
Thanks
Chris
Old 06-09-2010, 06:20 PM   #4
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Nice piece !!
That should keep people from breaking things under hard launch.
speedster is offline   Reply With Quote
Old 06-10-2010, 07:53 PM   #5
Ghost-Rider
Drives: SW 2SS/RS
Thanks
Chris
Black e-coat is the way to go.... be careful with zinc plate on hardened parts - hydrogen embrittlement can be a concern.
Old 06-16-2010, 07:15 PM   #6
GFORCE1320
Drives: 05 GTO
My new billet pinion yokes have arroused the interest of a few driveshaft companies, maybe there will be more driveshaft options here real soon.
Old 06-16-2010, 10:20 PM   #7
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
You are so right!! I had a guy steal axles from my display that had this done just to look nice,anyway they broke on him and left him stranded LOL!..Im sure chris has this worked out.
Hendrix-Engineering is offline   Reply With Quote
Old 06-16-2010, 10:29 PM   #8
GFORCE1320
Drives: 05 GTO
Oh yea, I have it worked out. It's not so much of a problem with 4340 and 300m materials as it is with chromoly.
The temp and process also has alot to do with it.
Thanks
Chris
Old 06-17-2010, 01:33 PM   #9
Ghost-Rider
Drives: SW 2SS/RS
It's a problem with any carbon alloy steel hardened above 39 Rc including 4340, 300M, Maraging, etc. Just ask the engineers that work on landing gear over at Boeing. A very special and lengthy baking process immediately after plating must be done - even then there is still a concern of hydrogen embrittlement. This is why you will never see plated high strength bolts from a reputable manufacturer.
Old 06-17-2010, 01:54 PM   #10
GFORCE1320
Drives: 05 GTO
Yes, I know all this. I am actually an ex-Boeing engineer my self. We use an aircraft spec coating process on our stuff.
Thanks for the heads up though.
Chris @ Gforce
Old 06-17-2010, 07:17 PM   #11
Ghost-Rider
Drives: SW 2SS/RS
Chris @ Gforce
Sounds like you're on top of it! BTW- those axles in your sig look incredible Props to having some very cool products.
Camaro Product Manager - interview Moose 5th Gen Camaro SS LS LT General Discussions 11 04-04-2012 06:10 PM
Laws Protecting Consumers for Aftermarket Parts strauchpete Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 9 01-17-2010 08:31 AM
New product, billet upper radiator mounts mike@newera Cosmetics and Lighting Modification Discussions 0 11-04-2009 02:37 PM
IMPORTANT Part 1 Warranty Disputes Zeus Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 11 08-25-2009 11:37 AM
