TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Member Car Journals
Old 04-20-2010, 08:50 PM   #1
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
Diarmadhi's Camaro (1SS:RS:LS3:SW/BLK)
Current status -
Cruising, just over 65000 miles of pure joy so far...
Too much done to go into details, just a quick overview of the last 9-12 months! One Big thing of note though... Its almost time to drop the trunk!
Underhood jump point (positive terminal) removed - bracket is gone and cable spliced/shrink wrapped
Torq solutions engine mounts installed
Hotchkiss Lowering springs installed (nice match to the Hotchkiss sways I have)
Almost all the bushings are done around the car, just the diff and rear subframe left to do...
- front control arm (pfadt spherical) - Done
- front radius arm (pfadt aluminum/poly) - Done
- rear control arm (pfadt aluminum/poly) - Done
- all the rear trailing and toe bushing were done with the (pfadt) arm package
Braille 15lb battery (relocated in rear trunk area with custom aluminum mount)
Barton 1st gen (stick) short throw shifter
2nd set of stock wheels (20X9 square for track with Michelin PSS 275/35, 20X8 square for street) complete with TPMS
Redline D4 in the Trans (at 55k)
Out of warranty so its all good now!
Mods in order below...
Stock Specs:
Order Information
Model Year: 2010
Division: CHEVROLET
Distrib. Entity: RET
Order Type: TRE - Retail Stock
Allocation Group: CAM
Model: 1ES37 - Camaro: 1SS Coupe
MSRP w/DFC: $33,130.00
Current Event: 6000 - Delivered
VIN: 2G1FS1EW5A9211363
Vehicle Specifications
PEG: 1SS - 1SS
Trim: AFJ - Black Sport Cloth
Primary Color: GAZ - Summit White
Engine: LS3 - 6.2L V8 Engine (Manual Transmission)
Emissions:
Transmission: MN6 - Manual 6 Speed Transmission
Ordered Options:
B34: Carpeted floor mats, front
FE9: Federal Emissions
SGC: Spare Tire and Wheel Not Desired
VLI: LPO, Cargo Mat
WRS: RS Exterior Package
Pictures:
5/4/2010
5/13/2010
7/3/2011 (Tie rods and trailing arms)
9/17/11 (GM White Interior Trim Kit)
7/12/12
9/15/12 - Stainless Steel Knurled Thumb Screws and Floating Hood (hood strut and mount delete).
4/30/13 - Custom coil pack bracket (aluminium - 1.5lbs weight savings). Carbon fiber replacements planned.
Mod History
  • Skip Shift Eliminator (LINK) - Purchased ($12.50)[Installed 5/15/2010]
  • Wheel locks (LINK) - Purchased ($22.86) [Installed 5/13/2010]
  • Chrome Locking Gas Door (LINK) - Purchased ($183.62) [Installed 5/13/2010]
  • Ghost Armor Radio Cover - Purchased ($25.00) [Installed 4/16/11]
  • Vararam Cold Air Intake - Gift ($0.00) [Installed 5/6/2011]
  • Custom Front bowtie (SSX Sema Style) - Purchased materials ($39.99) In Fabrication (90% complete)
  • Custom Vararam/Radiator top mounts - Fabricated ($0.00) [Installed 5/18/2011]
  • Pfadt rear trailing arms - (LINK) - Purchased ($395.00) [Installed 7/3/11]
  • Pfadt Rear Toe Rods - Purchased (package with trailing arms) [Installed 7/3/11]
  • GM Accessories White interior trim kit - Purchased ($359.00) [Installed 9/17/11]
  • Heater hose relocation - Purchased ($39.00) [Installed 10/16/11]
  • Vmax Ported throttle body - Purchased ($165.00) [Installed 2/26/12]
  • Hotchkiss Sway bar kit #22109 - Purchased/raffle ($160.00) [Installed 6/30/12]
  • VIS AMS Hood - Purchased ($900.00) [Installed 7/12/12]
  • Washer bottle delete - [Performed 7/29/12]
  • Hood strut and strut mount delete, Knurled Thumbscrew for hood prop - Purchased ($3.95) [Performed 9/15/12]
  • Hood Pins (functional, hood latch to be removed on change to non-daily driver) - Purchased ($19.95) [Performed 10/3/12]
  • Custom Coil Pack Brackets - Purchased (Fast-Stache Industries LLC) [Installed 4/30/13]
  • Battery Post Delete - [Performed 6/10/13]
  • Bushings (front spherical, front aluminum/poly, rear aluminum/poly) - Purchased ($114.99) [Installed 2/22/14]
  • Barton (1st gen) Stick Short Throw Shifter - Purchased ($100) [Installed 3/13/14]
  • Torq Solutions Engine Mounts - Purchased ($130) [Installed 3/13/14]
  • 2nd Set of Stock Wheels, 20x9 Track setup, 20x8 daily driver setup - Purchased ($600) [Installed 4/3/14]
  • Hotchkiss Lowering Springs - Purchased (Undisclosed) [Installed 4/3/14]
  • Braile Battery & Mount - Purchased (Battery $199.00) [Installed 5/24/14]
Future Plans (0-5 Years):
  • Drop Trunk Floor
  • Custom Exhaust
  • Custom Hockey Stripes (Black - Painted) (LINK)
  • Pfadt solid subframe bushings (LINK)
  • Electric water pump (LINK)
  • Racing Brake Rotors (all 4 corners)
  • Short Throw shifter
  • PDIM
  • Steering Wheel Audio Controls
  • Custom Interior Paint
  • Engine Bay Cleanup
Longterm Plans (5+ Years):
  • Cor Forged Wheels
  • Underhood cleanup (relocated coil packs, rewire/tape harness, polish or paint brackets, re-engineer hoses and lines)
  • Level 5 rear axles (LINK)
  • Aluminum Single Drive Shaft
  • Possible reprogram of bcm for custom screens (I'm a Software Engineer)
  • Hundreds of other small things that make it mine!
Total Mods Cost:
$3,469.86
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 04-20-2010, 08:51 PM   #2
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Reserved
Maintenance Post:
Format
Date - Mileage - Service Performed
[Parts Used (Part #, Quantity)]
Comments
5/31/2010 - 1113 - Oil Change, Multi-point Inspection
[Mobile 1 Oil Filter (M1113, 1), Mobile 1 Full Synthetic Oil (98HC63, 8 Quarts)]
Checked oil level, Washer Fluid level, Brake/Clutch fluid level and cleanliness, power steering fluid level, Coolant level, Air filter, tire pressure. All within specs. Wheel lug nuts torqued to 145 ft/lbs, oil drain plug torqued to 45 ft/lbs.
12/18/2010 - 10863 - Oil Change, Multi-point Inspection
3/31/2011 - 14862 - Insurance Claim
Body Work - Driver side between door and rear wheel (road debris caused body/paint damage)
Lifetime warranty on work with Elite Collision Center
7/23/2011 - 18992 - Oil Change, Multi-point Inspection
10/20/2011 - 22573 - Replacement tires
Qty - 2 Nitto Invo 245/45/20
Qty - 2 Nitto Invo 275/40/20
1/28/2012 - 27899 - Warranty Work @ Power Chevrolet
Replaced HVAC Blower (was squeeking), ordered new dash pad (cracked @ passenger airbag), ordered new catback exhaust (right muffler baffle spot welds broke), included Inspection.
2/4/2012 - 28010 - Oil Change, Differential fluid change, Multi-point Inspection
[Mobile 1 Oil Filter (M1113, 1), Mobile 1 Full Synthetic Oil (98HC63, 8 Quarts), Royal Purple MaxGear 75W90 1 Quart]
Checked oil level, Differential fluid level, Washer Fluid level, Brake/Clutch fluid level and cleanliness, power steering fluid level, Coolant level, Air filter, tire pressure. All within specs. Wheel lug nuts torqued to 145 ft/lbs, oil drain plug torqued to 45 ft/lbs.
2/23/2012 - 28459 - Warranty Work @ Power Chevrolet
Replaced dash pad (cracked @ passenger airbag), Replaced catback exhaust (right muffler baffle spot welds broke).
7/11/2012 - 38782 - Windshield Wiper Replacement
[OEM Replacement Driver Side (92231676, 1), OEM Replacement Passenger Side (92231677, 1)]
Replaced Driver and Passenger side windshield wipers.
9/9/2012 - 40798 - Oil Change, Multi-point Inspection
Checked oil level, Brake/Clutch fluid level and cleanliness, power steering fluid level, Coolant level, Air filter, tire pressure. All within specs. Wheel lug nuts torqued to 145 ft/lbs, oil drain plug torqued to 45 ft/lbs.
4/20/13 - 49851 - Oil Change, Clutch/Brake fluid change, Air Filter Recharge, Multi-point Inspection
[Mobile 1 Oil Filter (M1113, 1), Mobile 1 Full Synthetic Oil (98HC63, 8 Quarts), Preston Dot 4 Brake fluid]
5/11/13 - 50502 - Differential fluid change
[Royal Purple MaxGear 75W90 1 Quart]
5/??/13 - 50XXX - Replacement tires
Qty - 2 Nitto NT05 275/40/20
Old 04-20-2010, 08:51 PM   #3
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Reserved
Fuel (CSV delinated)
Stats
Fill-ups: 154
Miles Driven (at last fill-up): 40101
Total Fuel Cost: $7,299.36
Averages
Miles Per Tank: 260.29 Miles
Gallons Per Fill-up: 13.62 Gallons
Tank MPG: 19.27 MPG
Price Per Gallon: $3.51
Price Per Tank: $47.40
Delivered 05/12/2010 - 16 Miles
Date,Start Mileage,End Mileage,Total Miles,Gallons,Tank MPG,Average MPG, tank $/gal ,Tank total Cost,Total Gas cost,Octane
05/16/10,16,239,223,14.540,15.34,15.34, $2.970 , $43.18 , $43.18 ,91
05/20/10,239,529,290,15.340,18.90,17.12, $2.930 , $44.95 , $88.13 ,91
05/24/10,529,799,270,15.580,17.33,17.19, $2.950 , $45.96 , $134.09 ,91
05/29/10,799,1069,270,15.660,17.24,17.20, $2.830 , $44.32 , $178.41 ,91
06/04/10,1069,1292,223,14.400,15.49,16.86, $2.770 , $39.89 , $218.30 ,91
06/24/10,1292,1575,283,15.410,18.36,17.11, $2.870 , $44.23 , $262.52 ,91
07/02/10,1575,1864,289,15.010,19.25,17.42, $2.990 , $44.88 , $307.40 ,91
07/06/10,1864,2188,324,15.420,21.01,17.87, $2.999 , $46.24 , $353.65 ,91
07/13/10,2188,2483,295,14.535,20.30,18.14, $2.919 , $42.43 , $396.08 ,91
07/18/10,2483,2754,271,14.235,19.04,18.23, $2.979 , $42.41 , $438.48 ,91
07/21/10,2754,3082,328,15.755,20.82,18.46, $2.899 , $45.67 , $484.16 ,91
07/26/10,3082,3383,301,15.096,19.94,18.59, $2.899 , $43.76 , $527.92 ,91
07/30/10,3383,3587,204,10.502,19.42,18.65, $2.959 , $31.08 , $558.99 ,91
07/30/10,3587,3922,335,15.573,21.51,18.85, $3.359 , $52.31 , $611.30 ,91
08/01/10,3922,4096,174,8.643,20.13,18.94, $3.599 , $31.11 , $642.41 ,91
08/02/10,4096,4418,322,14.432,22.31,19.15, $2.919 , $42.13 , $684.54 ,91
08/06/10,4418,4772,354,16.302,21.72,19.30, $2.899 , $47.26 , $731.80 ,91
08/11/10,4772,5065,293,14.588,20.09,19.34, $2.959 , $43.17 , $774.96 ,91
08/18/10,5065,5381,316,15.827,19.97,19.38, $2.939 , $46.52 , $821.48 ,91
08/25/10,5381,5672,291,14.838,19.61,19.39, $2.839 , $42.13 , $863.60 ,91
08/30/10,5672,5944,272,15.076,18.04,19.32, $2.879 , $43.40 , $907.01 ,91
09/08/10,5944,6241,297,15.795,18.80,19.30, $2.779 , $43.89 , $950.90 ,91
09/15/10,6241,6557,316,16.531,19.12,19.29, $2.819 , $46.60 , $997.50 ,91
09/22/10,6557,6859,302,14.758,20.46,19.34, $2.799 , $41.31 ," $1,038.81 ",91
09/29/10,6859,7139,280,14.445,19.38,19.34, $2.799 , $40.43 ," $1,079.24 ",91
10/04/10,7139,7312,173,8.654,19.99,19.37, $2.799 , $24.22 ," $1,103.46 ",91
10/11/10,7312,7579,267,13.913,19.19,19.36, $2.839 , $39.50 ," $1,142.96 ",91
10/16/10,7579,7868,289,15.281,18.91,19.35, $2.849 , $43.54 ," $1,186.50 ",91
10/22/10,7868,8158,290,15.474,18.74,19.32, $2.899 , $44.86 ," $1,231.36 ",91
10/27/10,8158,8435,277,15.352,18.04,19.28, $2.899 , $44.51 ," $1,275.86 ",91
11/08/10,8435,8711,276,14.581,18.93,19.27, $2.939 , $42.85 ," $1,318.72 ",91
11/14/10,8711,8990,279,14.654,19.04,19.26, $2.879 , $42.19 ," $1,360.91 ",91
11/19/10,8990,9296,306,15.211,20.12,19.29, $2.959 , $45.01 ," $1,405.91 ",91
11/24/10,9296,9537,241,12.223,19.72,19.30, $2.939 , $35.92 ," $1,441.84 ",91
12/01/10,9537,9845,308,16.257,18.95,19.29, $2.899 , $47.13 ," $1,488.97 ",91
12/04/10,9845,10061,216,11.805,18.30,19.26, $2.919 , $34.46 ," $1,523.43 ",91
12/10/10,10061,10341,280,14.128,19.82,19.28, $3.019 , $42.65 ," $1,566.08 ",91
12/14/10,10341,10651,310,15.007,20.66,19.32, $3.059 , $45.91 ," $1,611.98 ",91
12/20/10,10651,10919,268,14.710,18.22,19.29, $3.059 , $45.00 ," $1,656.98 ",91
12/28/10,10919,11202,283,15.435,18.33,19.26, $3.059 , $47.22 ," $1,704.20 ",91
01/03/11,11202,11497,295,15.342,19.23,19.26, $3.069 , $47.08 ," $1,751.28 ",91
01/11/11,11497,11774,277,15.139,18.30,19.24, $3.079 , $46.61 ," $1,797.90 ",91
01/18/11,11774,12050,276,14.804,18.64,19.23, $3.089 , $45.73 ," $1,843.63 ",91
01/25/11,12050,12324,274,15.121,18.12,19.20, $3.199 , $48.37 ," $1,892.00 ",91
02/03/11,12324,12606,282,16.204,17.40,19.16, $3.259 , $52.81 ," $1,944.81 ",91
02/09/11,12606,12887,281,15.232,18.45,19.15, $3.359 , $51.16 ," $1,995.97 ",91
02/16/11,12887,13152,265,14.750,17.97,19.12, $3.459 , $51.02 ," $2,046.99 ",91
02/23/11,13152,13415,263,14.820,17.75,19.09, $3.399 , $50.37 ," $2,097.36 ",91
03/01/11,13415,13697,282,14.762,19.10,19.09, $3.559 , $52.54 ," $2,149.90 ",91
03/06/11,13697,13986,289,14.662,19.71,19.10, $3.599 , $52.77 ," $2,202.67 ",91
03/11/11,13986,14280,294,15.095,19.48,19.11, $3.699 , $55.84 ," $2,258.51 ",91
03/21/11,14280,14594,314,15.629,20.09,19.13, $3.659 , $57.19 ," $2,315.69 ",91
03/31/11,14594,14881,287,14.835,19.35,19.13, $3.799 , $56.36 ," $2,372.05 ",91
04/13/11,14881,15104,223,12.726,17.52,19.10, $3.859 , $49.11 ," $2,421.16 ",91
04/15/11,15104,15151,47,5.343,8.80,18.92, $4.049 , $21.63 ," $2,442.80 ",91
04/17/11,15151,15426,275,15.861,17.34,18.89, $3.849 , $61.05 ," $2,503.84 ",91
04/24/11,15426,15677,251,13.480,18.62,18.88, $3.859 , $52.02 ," $2,555.86 ",91
04/29/11,15677,15969,292,15.157,19.27,18.89, $3.919 , $59.40 ," $2,615.26 ",91
05/06/11,15969,16246,277,15.256,18.16,18.88, $3.919 , $59.79 ," $2,675.05 ",91
05/13/11,16246,16529,283,15.862,17.84,18.86, $3.959 , $62.80 ," $2,737.85 ",91
05/20/11,16529,16819,290,15.325,18.92,18.86, $3.919 , $60.06 ," $2,797.91 ",91
05/28/11,16819,17099,280,14.872,18.83,18.86, $3.859 , $57.39 ," $2,855.30 ",91
06/13/11,17099,17378,279,15.455,18.05,18.85, $3.779 , $58.40 ," $2,913.70 ",91
06/21/11,17378,17656,278,15.511,17.92,18.83, $3.659 , $56.75 ," $2,970.46 ",91
06/30/11,17656,17942,286,15.283,18.71,18.83, $3.539 , $54.09 ," $3,024.55 ",91
07/07/11,17942,18228,286,15.994,17.88,18.82, $3.459 , $55.32 ," $3,079.87 ",91
07/13/11,18228,18523,295,15.395,19.16,18.82, $3.459 , $53.25 ," $3,133.12 ",91
07/23/11,18523,18816,293,15.593,18.79,18.82, $3.479 , $54.25 ," $3,187.37 ",91
07/28/11,18816,19090,274,14.600,18.77,18.82, $3.459 , $50.50 ," $3,237.87 ",91
08/02/11,19090,19231,141,8.430,16.73,18.79, $3.479 , $29.33 ," $3,267.20 ",91
08/02/11,19231,19435,204,8.538,23.89,18.86, $3.699 , $31.58 ," $3,298.78 ",91
08/04/11,19435,19680,245,10.802,22.68,18.92, $3.999 , $43.20 ," $3,341.98 ",91
08/04/11,19680,19836,156,6.066,25.72,19.01, $3.699 , $22.44 ," $3,364.41 ",91
08/08/11,19836,20167,331,16.110,20.55,19.03, $3.459 , $55.72 ," $3,420.14 ",91
08/15/11,20167,20420,253,14.831,17.06,19.00, $3.499 , $51.89 ," $3,472.03 ",91
08/22/11,20420,20671,251,14.879,16.87,18.98, $3.399 , $50.57 ," $3,522.61 ",91
08/30/11,20671,20925,254,14.984,16.95,18.95, $3.419 , $51.23 ," $3,573.84 ",91
09/08/11,20925,21195,270,15.319,17.63,18.93, $3.599 , $55.13 ," $3,628.97 ",91
09/15/11,21195,21456,261,14.797,17.64,18.92, $3.579 , $52.96 ," $3,681.93 ",91
09/24/11,21456,21738,282,15.268,18.47,18.91, $3.539 , $54.03 ," $3,735.96 ",91
10/02/11,21738,21973,235,12.915,18.20,18.90, $3.539 , $45.71 ," $3,781.67 ",91
10/09/11,21973,22257,284,15.266,18.60,18.90, $3.519 , $53.72 ," $3,835.39 ",91
10/18/11,22257,22534,277,15.258,18.15,18.89, $3.519 , $53.69 ," $3,889.08 ",91
10/25/11,22534,22786,252,14.586,17.28,18.87, $3.429 , $50.02 ," $3,939.10 ",91
10/30/11,22786,23030,244,14.608,16.70,18.84, $3.559 , $51.99 ," $3,991.09 ",91
10/31/11,23030,23084,54,14.720,3.67,18.67, $3.559 , $52.39 ," $4,043.48 ",91
11/06/11,23084,23332,248,14.262,17.39,18.65, $3.369 , $48.05 ," $4,091.52 ",91
11/12/11,23332,23565,233,13.698,17.01,18.63, $3.559 , $48.75 ," $4,140.28 ",91
11/15/11,23565,23848,283,13.493,20.97,18.66, $3.519 , $47.48 ," $4,187.76 ",91
11/18/11,23848,23965,117,7.127,16.42,18.64, $3.519 , $25.08 ," $4,212.84 ",91
11/18/11,23965,24173,208,9.648,21.56,18.67, $3.599 , $34.72 ," $4,247.56 ",91
11/20/11,24173,24383,210,10.033,20.93,18.69, $4.039 , $40.52 ," $4,288.08 ",91
11/20/11,24383,24528,145,6.223,23.30,18.74, $3.599 , $22.40 ," $4,310.48 ",91
11/23/11,24528,24825,297,15.523,19.13,18.75, $3.379 , $52.45 ," $4,362.93 ",91
12/01/11,24825,25116,291,15.945,18.25,18.74, $3.339 , $53.24 ," $4,416.17 ",91
12/09/11,25116,25380,264,15.165,17.41,18.73, $3.349 , $50.79 ," $4,466.96 ",91
12/15/11,25380,25663,283,15.427,18.34,18.72, $3.349 , $51.67 ," $4,518.63 ",91
12/22/11,25663,25931,268,15.639,17.14,18.71, $3.379 , $52.84 ," $4,571.47 ",91
12/30/11,25931,26211,280,15.448,18.13,18.70, $3.459 , $53.43 ," $4,624.90 ",91
01/06/12,26211,26479,268,14.351,18.67,18.70, $3.499 , $50.21 ," $4,675.12 ",91
01/15/12,26479,26734,255,15.584,16.36,18.68, $3.559 , $55.46 ," $4,730.58 ",91
01/24/12,26734,27000,266,14.985,17.75,18.67, $3.559 , $53.33 ," $4,783.91 ",91
01/27/12,27000,27105,105,6.500,16.15,18.64, $3.699 , $24.04 ," $4,807.96 ",91
01/27/12,27105,27388,283,13.109,21.59,18.67, $3.759 , $49.28 ," $4,857.23 ",91
01/29/12,27388,27563,175,9.910,17.66,18.66, $3.689 , $36.56 ," $4,893.79 ",91
01/31/12,27563,27881,318,14.875,21.38,18.69, $3.639 , $54.13 ," $4,947.92 ",91
02/08/12,27881,28117,236,13.873,17.01,18.67, $3.709 , $51.45 ," $4,999.38 ",91
02/21/12,28117,28371,254,15.997,15.88,18.65, $3.829 , $61.25 ," $5,060.63 ",91
02/28/12,28371,28603,232,13.945,16.64,18.63, $4.059 , $56.60 ," $5,117.23 ",91
03/06/12,28603,28871,268,16.102,16.64,18.61, $4.159 , $66.97 ," $5,184.20 ",91
03/12/12,28871,29175,304,15.912,19.11,18.62, $4.119 , $65.54 ," $5,249.74 ",91
03/19/12,29175,29464,289,15.399,18.77,18.62, $4.209 , $64.81 ," $5,314.56 ",91
03/27/12,29464,29699,235,14.181,16.57,18.60, $4.249 , $60.26 ," $5,374.81 ",91
04/03/12,29699,29953,254,15.152,16.76,18.58, $4.139 , $62.71 ," $5,437.53 ",91
04/09/12,29953,30229,276,15.093,18.29,18.58, $4.089 , $61.72 ," $5,499.24 ",91
04/13/12,30229,30397,168,9.521,17.65,18.57, $4.139 , $39.41 ," $5,538.65 ",91
04/15/12,30397,30644,247,11.910,20.74,18.59, $4.259 , $50.72 ," $5,589.37 ",91
04/18/12,30644,30978,334,16.490,20.25,18.60, $4.049 , $66.77 ," $5,656.14 ",91
04/19/12,30978,31268,290,13.471,21.53,18.63, $4.399 , $59.26 ," $5,715.40 ",91
04/20/12,31268,31367,99,4.123,24.01,18.67, $4.189 , $17.27 ," $5,732.67 ",91
04/20/12,31367,31548,181,9.039,20.02,18.69, $4.199 , $37.95 ," $5,770.63 ",91
04/20/12,31548,31803,255,11.026,23.13,18.72, $3.989 , $43.98 ," $5,814.61 ",91
04/24/12,31803,32055,252,11.210,22.48,18.75, $3.999 , $44.83 ," $5,859.44 ",91
04/24/12,32055,32326,271,11.895,22.78,18.78, $4.159 , $49.47 ," $5,908.91 ",91
04/24/12,32326,32558,232,10.025,23.14,18.82, $4.099 , $41.09 ," $5,950.00 ",91
04/24/12,32558,32694,136,6.675,20.37,18.83, $3.999 , $26.69 ," $5,976.69 ",91
04/29/12,32694,33038,344,14.945,23.02,18.86, $4.099 , $61.26 ," $6,037.95 ",91
05/09/12,33038,33331,293,14.725,19.90,18.87, $4.039 , $59.47 ," $6,097.43 ",91
05/16/12,33331,33597,266,14.355,18.53,18.87, $4.059 , $58.27 ," $6,155.70 ",91
05/23/12,33597,33860,263,13.883,18.94,18.87, $3.959 , $54.96 ," $6,210.66 ",91
06/04/12,33860,34142,282,14.876,18.96,18.87, $3.899 , $58.00 ," $6,268.66 ",91
06/09/12,34142,34441,299,15.292,19.55,18.88, $3.839 , $58.71 ," $6,327.37 ",91
06/15/12,34441,34718,277,15.550,17.81,18.87, $3.759 , $58.45 ," $6,385.82 ",91
06/23/12,34718,35008,290,15.993,18.13,18.86, $3.739 , $59.80 ," $6,445.62 ",91
06/29/12,35008,35293,285,14.709,19.38,18.87, $3.639 , $53.53 ," $6,499.14 ",91
07/07/12,35293,35587,294,15.488,18.98,18.87, $3.599 , $55.74 ," $6,554.88 ",91
07/13/12,35587,35867,280,14.920,18.77,18.87, $3.439 , $51.31 ," $6,606.19 ",91
07/21/12,35867,36159,292,15.346,19.03,18.87, $3.489 , $53.54 ," $6,659.74 ",91
07/26/12,36159,36437,278,14.327,19.40,18.87, $3.419 , $48.98 ," $6,708.72 ",91
07/30/12,36437,36612,175,8.777,19.94,18.88, $3.219 , $28.25 ," $6,736.97 ",91
07/30/12,36612,36810,198,8.362,23.68,18.91, $3.399 , $28.42 ," $6,765.39 ",91
07/30/12,36810,37139,329,13.129,25.06,18.96, $3.659 , $48.04 ," $6,813.43 ",91
07/31/12,37139,37408,269,11.543,23.30,18.99, $3.799 , $43.85 ," $6,857.29 ",89
07/31/12,37408,37538,130,5.131,25.34,19.03, $3.659 , $18.77 ," $6,876.06 ",89
08/01/12,37538,37795,257,11.327,22.69,19.06, $3.559 , $40.31 ," $6,916.37 ",90
08/01/12,37795,37925,130,5.880,22.11,19.08, $3.799 , $22.34 ," $6,938.71 ",93
08/01/12,37925,38239,314,12.813,24.51,19.11, $4.159 , $53.29 ," $6,992.00 ",93
08/05/12,38239,38427,188,11.647,16.14,19.09, $4.119 , $47.97 ," $7,039.97 ",93
08/05/12,38427,38736,309,12.998,23.77,19.13, $3.599 , $46.78 ," $7,086.75 ",90
08/05/12,38736,38910,174,7.332,23.73,19.16, $3.859 , $28.29 ," $7,115.05 ",90
08/06/12,38910,39105,195,8.603,22.67,19.18, $3.999 , $34.40 ," $7,149.45 ",90
08/06/12,39105,39388,283,11.865,23.85,19.21, $3.699 , $43.89 ," $7,193.34 ",91
08/06/12,39388,39724,336,13.852,24.26,19.24, $3.509 , $48.61 ," $7,241.95 ",91
08/09/12,39724,40101,377,16.131,23.37,19.27, $3.559 , $57.41 ," $7,299.36 ",91
Misc
Old 04-21-2010, 06:48 AM   #4
Mojave
San Diego Head Tuners
Mojave's Avatar
Drives: 2016 Camaro 1SS ,NPP,MagRide, A8
Congrats and cloth is the only way to go for an Arizona car. Good choice
2016 1SS A8, NPP, MagRide, Black Rims
My 5th Camaro (3 Gen5, 1 Gen4)
Member of San Diego Head Tuners
https://www.youtube.com/c/MojaveKY
https://www.instagram.com/mojaveky/
https://twitter.com/MojaveKY
http://dinowax.refr.cc/bryanm 15% off DinoWax orders
Mojave is offline   Reply With Quote
Old 04-24-2010, 09:19 AM   #5
tgdtown
tgdtown's Avatar
Drives: Cyber Gray 2SS -RS
Pics, please...
tgdtown is offline   Reply With Quote
Old 05-04-2010, 11:45 PM   #6
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Originally Posted by tgdtown View Post
Pics, please...
As requested! Cant wait to get her!
Thanks for he photos Scott!
Old 05-05-2010, 12:42 AM   #7
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Location: In the happy padded room wearing a jacket that makes me hug myself...
Congrats D!!! It's been a long time in waiting. You're finally getting it done. I can't wait to see it in October.
Blue Rush, 2010 SS [Car of the Week 3/22/2010] Traded in on...ZLZBUBB, 2013 ZL1
Mindz is offline   Reply With Quote
Old 05-14-2010, 07:05 PM   #8
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Updated
- Locking Chrome Fuel Door
- Security Lug Nuts
- Fuel Tracking Format
Old 05-29-2010, 04:38 PM   #9
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Hit 1k miles Friday May 28th on the home from work.
Stopped by checker to pickup the stuff for the first oil change.
9 quarts Mobile 1 Full Synthetic 5W30 (Part # 98HC63)
1 Mobile 1 oil Filter (Part # M1113)
change to happen today or tomorrow!
Old 05-29-2010, 04:54 PM   #10
CamaroScotty
Drives: Your new SLP Camaro!
Send a message via Yahoo to CamaroScotty
1000??? You are out CRUISING!!!!
CamaroScotty is offline   Reply With Quote
Old 05-29-2010, 05:55 PM   #11
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Having a great time with the car... and a 40 mile round trip commute
Yea I need to back off the mileage a bit. will happen after my vacation next week (2 weeks with no Camaro!).
Old 05-29-2010, 06:13 PM   #12
2010 SSRS
2010 SSRS's Avatar
Drives: 3 V8 Camaros
congrats
Old 05-29-2010, 06:38 PM   #13
guiLT
Tampa Gulf Coast Family
guiLT's Avatar
Drives: 2001 Maxima
CONGRATS!
guiLT is offline   Reply With Quote
Old 09-25-2010, 12:24 AM   #14
The_Stache
SoCal Race Team #13
The_Stache's Avatar
If you want to see this pretty much stock, but rare combination, Camaro...
I will be @ the Duel in the Desert the weekend of October 22nd
AND
C5F2 in April!
PS. - My garage / tools / air compressor will be available for those who want to wrench at either event. Just gotta let me know ahead of time and we will work something out!
GM unveils Jay Leno Camaro, Camaro Synergy, Camaro Chroma, Camaro Dusk at SEMA irocnroll 5th Gen Camaro SS LS LT General Discussions 101 02-27-2012 12:25 PM
Gran Turismo 5... No Camaro? 5thGenOwner 5th Gen Camaro SS LS LT General Discussions 111 12-06-2011 10:06 AM
GM memo to dealers Moose 5th Gen Camaro SS LS LT General Discussions 41 02-04-2010 07:33 PM
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 338 04-15-2009 05:33 PM
