Old 04-08-2010, 10:51 AM   #1
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
I need a math wiz, not car related
Ok folks, I need someone to help me with this problem, I get a diff answer than the book using the same formula for every other problem, and I dont know WTF!
Effort = Resistance x Resistance Distance / Effort Distance
Three people are trying to raise a 30-foot flagpole that measures 3 inches in diameter. The total weight of the flagpole is 95lbs. If one person served as the fulcrum by anchoring the end of the flagpole to the ground, and the other two people attempted to lift the flagpole at a point 12 feet from the fulcrum, how much resistance would they encounter?
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 04-08-2010, 11:22 AM   #2
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
So would that be
E=(95*30)/18
E=158.3 Repeating?
Moriartii is offline   Reply With Quote
Old 04-08-2010, 11:58 AM   #3
BigRigMike
BigRigMike's Avatar
Drives: 2010 Ford Fusion
Is the answer 118.75?
BigRigMike is offline   Reply With Quote
Old 04-08-2010, 12:14 PM   #4
Jeanius
Jeanius's Avatar
According to the book it is!
How did u get it?
TRADED: 2016 2SS M6
Old 04-08-2010, 12:21 PM   #5
BigRigMike
BigRigMike's Avatar
Resistance = 95lbs
Effort distance = 12 Ft
Resistance distance = 15ft - I assume this is where we differ because you should be using the center of gravity of the pole which is the middle or 15ft
Old 04-08-2010, 12:23 PM   #6
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Resistance = 95lbs
This is the answer I got as well.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 04-08-2010, 12:25 PM   #7
Moriartii
Moriartii's Avatar
But that assumes the CG is in the center of the pole which it is not since it is anchored at the end. So the RD would actually be 30 ft minus the fulcrum location of 12ft making it 18ft??
Cheers
K
Old 04-08-2010, 12:27 PM   #8
ron10
Drives: 2010 2SS IOM L99
ron10 is offline   Reply With Quote
Old 04-08-2010, 12:28 PM   #9
AnnaBear@SpartaChevy
Drives: 2011 Camaro 1SS Manual Synergy Grn
Send a message via Yahoo to AnnaBear@SpartaChevy
Where to even start?!
AnnaBear@SpartaChevy is offline   Reply With Quote
Old 04-08-2010, 12:29 PM   #10
Xanthos
PWA Relapse
Xanthos's Avatar
Cheers
K
But the fulcrum location is not at 12ft, its at 0ft because thats where the pole is anchored. Assuming that its a constant density, the center of gravity would be the halfway point of the pole.
- X
Old 04-08-2010, 12:30 PM   #11
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
Wouldn't the resistance vary (become easier as you lift the pole because the center of gravity changes as the angle of the pole approaches 90 degrees?
tradosaurus is offline   Reply With Quote
Old 04-08-2010, 12:31 PM   #12
Moriartii
Moriartii's Avatar
Ah I see what you are saying.
Cheers
K
Old 04-08-2010, 12:33 PM   #13
Xanthos
PWA Relapse
Xanthos's Avatar
Yes, but that could be said about any situation. This equation just solves for the force at a given point in time. In this case, immediately as you begin to lift.
- X
Old 04-08-2010, 12:38 PM   #14
Jeanius
Jeanius's Avatar
Cheers
K
Thats what I thought too
thanks guys for the help, it makes sense now
TRADED: 2016 2SS M6
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 12:04 AM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
1st Car Show and meeting Al Oppenheiser! scrming 5th Gen Camaro SS LS LT General Discussions 44 08-17-2009 04:46 PM
09 Mustang GT and 09 Challenger R/T test drives CamaroSpike23 General Automotive + Other Cars Discussion 19 04-10-2009 04:27 PM
