Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 03-12-2010, 07:06 AM   #1
bmwdon
I refuse to go smurfy
bmwdon's Avatar
Drives: 2009 Challenger SRT8, 2010 Camaro
LLT V6 stock flowrates....simply sad!
Matt D.'s stock flowrate #'s....we should see worked heads in the next day or two as he's cutting the valve job later today, and he'll be looking at the t/b and intake manifold soon as they show up at his shop tonight, UPS brought them back to my house lastweek as I forgot to remove an old label on one side and it was to me...so those are a week behind schedule, my fault. But anyways, here's what the stock heads are doing
"Intake
.200 188
.300 255
.400 275
.450 281
.500 284
Exhaust
.200 135
.300 152
.400 160
.450 162
.500 164
flowed at 28" of h2o on a sf-600
After .500" lift they started to level out I still haven't decided what valve job cutter I want to use yet, I may use a little shallower seat angle but I may leave it a 45 degree seat." And don't forget these are port matched to the BBK long tubes that Phastek had as a pre-production set for testing.
Here's some of the V8 #'s he's pulled from the heads he's worked depending on the shortblock setup such as displacement and compression ratio....hope we can see similar flow rates, atleast up to .5-.6" as the stock cams only open up that far on the V6 heads. I wish I had some stock V8 SS flowrates to compare to instead.
Intake Exhaust
.200" 158 .200" 117
.300" 236 .300" 183
.400" 294 .400" 226
.500" 346 .500" 241
.600" 361 .600" 250
.700" 378 .700" 255
Intake Exhaust
.200" 162 .200" 118
.300" 249 .300" 180
.400" 306 .400" 222
.500" 339 .500" 239
.600" 355 .600" 246
.700" 363 .700" 251
-Bill...the Camaro was my wifes, now she's got a minivan
Challenger- 2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH
bmwdon is offline   Reply With Quote
Old 03-12-2010, 07:17 AM   #2
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
Send a message via AIM to Blade
I honestly can't figure out what those numbers mean But thanks for the work. Hopefully you guys come up with a better manifold to use.
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner
2010 LT/RS Build Thread - Traded in for 2012 2SS
2007 Acura TSX
1992 Oldsmobile Achieva V6
1992 Mercury Sable
Blade is offline   Reply With Quote
Old 03-12-2010, 07:18 AM   #3
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
Hey Don... got any photos of the stock ports?
Beauwulf is offline   Reply With Quote
Old 03-12-2010, 07:22 AM   #4
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Glad I'm not alone! LOL! Guess I know what I'll be reading up on this weekend!
scrming is offline   Reply With Quote
Old 03-12-2010, 07:28 AM   #5
Beauwulf
Beauwulf's Avatar
Pretty simple really... flow rates in CFM at .2" ~.3"~.4" ~ ETC of lift at the valve.
Old 03-12-2010, 07:30 AM   #6
pleigh
pleigh's Avatar
Drives: 2010 CGM 1LT A6
"Intake
.200 188
.300 255
.400 275
.450 281
.500 284
Exhaust
.200 135
.300 152
.400 160
.450 162
.500 164
Intake Exhaust
.200" 158 .200" 117
.300" 236 .300" 183
.400" 294 .400" 226
.500" 346 .500" 241
.600" 361 .600" 250
.700" 378 .700" 255
Intake Exhaust
.200" 162 .200" 118
.300" 249 .300" 180
.400" 306 .400" 222
.500" 339 .500" 239
.600" 355 .600" 246
.700" 363 .700" 251
Does your wife know what you're doing to her car?
1LT A6, 19" polished rims, MRT 1.0 exhaust, Boston Acoustics, C&C package, Tint
NO, the Rev limiter is not set to 118MPH... and YES, driving in this manner does affect MPG...
pleigh is offline   Reply With Quote
Old 03-12-2010, 07:32 AM   #7
Blade
Blade's Avatar
Ok so I understand that part now. Can you tell me what units are the flow rates measured in?
Formerly owner of:
2007 Acura TSX
1992 Mercury Sable
Old 03-12-2010, 07:33 AM   #8
Beauwulf
Beauwulf's Avatar
cubic feet per minute
Old 03-12-2010, 07:38 AM   #9
scrming
scrming's Avatar
ah... ok.. makes since now! WOOHOO! No studying this weekend!
Old 03-12-2010, 07:41 AM   #10
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
at the valve.
Do you mean valve(s)? or is it computed per valve?
ROD1 is offline   Reply With Quote
Old 03-12-2010, 07:42 AM   #11
Beauwulf
Beauwulf's Avatar
Yea, it's measured at the end of the valve....
Old 03-12-2010, 07:46 AM   #12
bmwdon
bmwdon's Avatar
I don't, but Matt might, not sure if he took shots of those or not, I'll ask. I did post up pics of the porting he did on the first head, just no valve job cut yet. These are all I have at the moment.
And all the wife knows for now is the headers back exhaust and cai... too scared to tell her about the rest, and she's not technical enough to know if I did this or not
Old 03-12-2010, 07:59 AM   #13
Beauwulf
Beauwulf's Avatar
Hmmmm... you gonna change out the guides? They look a little thin around the holes. They may crack and chip off like that!
Interesting that in photo 3 they didn't add more radius to that ledge on the bottom. Was the material too thin there to take more out?
Old 03-12-2010, 08:01 AM   #14
bmwdon
bmwdon's Avatar
And I'm not going any bigger on the valves, just a 5 angle face. So I'm not expecting SS flowrates, but definitely expecting improved over stock V6 flow rates!! Matt says the intake side will see minor improvements, he worked the runners a little, and a little on the bowls.....but on the exhaust side, he got plenty of material out of the way, and he's not simply a hogger....he understands how to improve velocity through shaping the runners right. I can't wait to see the final #'s.....these with the lt headers/high flow cats is going to equal some nice gains. The cai with any porting on the intake side is going to be icing on the cake.
llt v6 cylinder heads
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 611 07-01-2020 08:49 AM
DIY Noweeds exhaust diverter installation CanadianCamaro Camaro DIY & HOW-TO instructions & discussions 42 08-15-2016 11:11 AM
In Terms of V6 Engines, Why Doesn't GM Simply "Go 4 It?" Cmicasa the Great XvX General Automotive + Other Cars Discussion 17 02-11-2010 11:35 AM
STOCK V6 2010 CAMARO et7333 Dragstrip and Launch Techniques Discussion 2 07-14-2009 09:37 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
