Old 05-23-2026, 03:28 PM   #1
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Banks iDash DataMonster with Banks WB O2 Sensor Issue (Solved)
Is anyone running the Banks iDash DataMonster/SuperGuage with the Bank's O2 WB sensor kit. I can't for the life of me get it to read AFR. I've followed the instructions to the letter. Power is good. The display doesn't move from 0. I've tried switching channels, tables, etc. Nothing seems to work. At this point, it looks like I'll have to give Banks a call and speak to one of their techs. Any guidance would be welcomed.
Kooks 1-7/8" Long Tube Headers / Kooks Hi-Flow Cats / Kooks X-Pipe / Borla S-Type NPP
GPI SS2 Cam / GPI Ported Heads / Katech Oil Pump / Katech Valley Cover / GPI Hardened Pushrods
BTR Valve Springs / Johnson 2110R Lifters / Ported LT2 Intake Manifold / Ported 95mm LT5 TB
Rotofab CAI / Mighty Mouse Catch Can / DSX Flex Fuel Sensor / Flex Tune
BMR Rear Cradle Lockout Kit / Katech VVT Delete kit / CHE Trunion Upgrade / LT1 HPFP
LME/GPI Timing Chain Guide / Katech Timing Chain / AFM Delete
Halo Tunnel Brace / MRR M017's wrapped in Goodyear SC3's / GM Lowering Kit
SSShark is offline   Reply With Quote
Old 05-25-2026, 07:09 AM   #2
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Do you have it connected using their Canbus converter to the iDash? Are you running one or two iDash units and selected which is the Master yet?
Patriot Motorsports USA is offline   Reply With Quote
Old 05-25-2026, 08:49 AM   #3
SSShark
SSShark's Avatar
I have one idash unit connected via obdII. It has two 6 pin connectors, the wideband module is connected to it via the second connector. Everything looks good as far as the installation instructions. I'm stumped.
Old 05-25-2026, 10:39 AM   #4
SSShark
SSShark's Avatar
Here are some gauge settings. The last photo gives the AFR options but they seem to be commanded, not readable, if that makes sense. I'm a little noobish when it comes to this so please bear with me
Old 05-26-2026, 07:07 PM   #5
SSShark
SSShark's Avatar
In case anyone running the same combination encounters the same issues, the 4 channel module required a firmware update. The update fixed the table voltages not saving. It's very strange since the latest update was from 2020 and I just recently purchased the unit. Below is a quick vid
https://youtube.com/shorts/9EGrlEtX2pk
Old 05-27-2026, 06:21 PM   #6
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
yours looks like a Gen1 unit (front loading SD card) versus the Gen2 (bottom loading SD card). That may be why you most recent update was from 2020.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 05-27-2026, 06:46 PM   #7
SSShark
SSShark's Avatar
Yes, the gauge is gen 1 but that firmware was fine (1.24). It turned out to be the 4 channel sensor that had the older firmware version. I never thought to update since the latest online download was from 2020. I was racking my brain for days trying to figure out the problem. Lesson learned.
