Old Today, 03:37 PM   #1
509Driver
509Driver's Avatar
Drives: 2018 Camaro 2SS, 1LE
Catch can install location
Heya everyone,
I recently upgraded from a 2.9L gen 4 whipple to a 3.0L gen 6, and I’m not 100% sure of correct connection to install my catch can. I was also curious if vented vs non-vented cans are that big of a deal on boosted applications. I’m only running 6-7lbs of boost if that makes a difference as well.
I’m pretty sure this is the correct location but I had a friend who blew his rear main seal due to an improperly installed catch can, so I might have a little PTSD from that, so I figured it couldn’t hurt to ask
Links to the photos in my Google Drive.
https://drive.google.com/file/d/1ZHJ...w?usp=drivesdk
https://drive.google.com/file/d/1khV...w?usp=drivesdk
https://drive.google.com/file/d/1aeb...w?usp=drivesdk
2018 Camaro 2SS 1LE
Current Mods: 2.9 Whipple SC, McLeod stage 2 Clutch, ARH 1" 7/8 Long Tube Headers, RotoFab CIA.
509Driver is offline   Reply With Quote
Old Today, 09:51 PM   #2
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
Do not mount a vented catch can and not keep a close watch on it due to oil vapor and oil dripping... in fact, if you are road racing or doing track days, several tracks will decline your tech inspection due to the fire hazard an open catch can has.
I designed a mount to place it forward on the core support and use the Improved Racing closed system with the custom fitting I made to utilize the OEM drainback to the crankcase. LMK if you need more info.
Click this link to see the catch can in action!!
Patriot Motorsports USA is online now   Reply With Quote
