Old 05-12-2026, 08:07 AM   #1
N00bmaster
Drives: 2018 Chevy Camaro 2SS
Engine noise help please. 2018 SS manual
My car got loud for a second at high RPM yesterday (not sure if I bounced off the limiter) and now it seems there’s ticking that wasn’t there before. Any help would be appreciated. Am I imagining it?
Here’s a video with some RPM’s.
https://youtube.com/shorts/0HJawKGHP...cdluyjmrvmHsEC
N00bmaster is offline   Reply With Quote
Old 05-12-2026, 08:12 AM   #2
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Definitely been there. Hopefully you're mechanically inclined. Otherwise it's about to get really expensive
bishopts is online now   Reply With Quote
Old 05-12-2026, 08:50 AM   #3
Uh-oh... that isn't a good sound, unfortunately. Your engine needs professional help.
Old 05-12-2026, 08:55 AM   #4
vince3
Drives: 2022 Vivid Orange LT1-M6
Loud at high rpm - what exactly does this mean? I hear typical LT1 noise in your video.
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 05-12-2026, 09:08 AM   #5
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Sounds a little more than the typical LT1 though. Could be exhaust leak, lifter, spring, loud DI or how about this.....what exactly were you doing when "car got loud for a second at high RPM" ??? Did you miss a shift? You say "not sure if I bounced off the limiter" Hmmm....Did you bend a pushrod Mr.??? Time to take the valve covers off or bring it to a mechanic. Maybe put a mechanics stethoscope on it first if you wanna poke around with it.
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 05-12-2026, 09:33 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Sounds like you have a lifter starting to go south.
Old 05-12-2026, 11:55 AM   #7
DeuceCam
Drives: LT1
You'd know if you hit the limiter, because all throttle is cut off by the ecu and the rpm's drop; it's very abrupt/startling (I don't like it). You can't 'bounce off' the limiter like on some other cars, unfortunately. However, I've never over-revved from a downshift, so I don't know what would happen in that situation.
DeuceCam is offline   Reply With Quote
Old 05-12-2026, 01:26 PM   #8
bishopts
bishopts's Avatar
I ran mine to 7400 rpm when i ran 3rd gear out and wasnt paying attention to how quickly it starts accelerating after 4000. It was when in first got my car. I bent a valve on cylinder 5. But also 2 pushrods.
Buying the head was cheaper than machine work plus valves. It was like $360 with valves from GM. Took about 4 hours to replace. The hardest part was getting the header out.
Old 05-12-2026, 03:17 PM   #9
bishopts
bishopts's Avatar
Pull the valve cover and inspect the rocker arms and pushrods. See if they have slack. Its pretty easy to do. For the most part it's a 10mm socket to do it all.
Old 05-12-2026, 04:26 PM   #10
JT6Speed
JT6Speed's Avatar
Drives: 2023 Camaro 1SS M6
Wow what's the rev limiter then?
Black 2023 Camaro 1SS Coupe M6
Ordered: April 2022-----Built: July 2022-----Delivered: September 2022
-Dual-Mode Exhaust (NPP)
-Red Painted Calipers (J6F)
-5 Split Spoke Bright Silver Painted Aluminum Wheels (56W)
-Chrome Camaro Logo Fender Badge
-Second Generation Front Splitter in Satin Black
JT6Speed is offline   Reply With Quote
Old 05-12-2026, 04:27 PM   #11
N00bmaster
Just called a shop and they said I’d be looking at around $2800 if it’s lifter. ��
Old 05-12-2026, 04:41 PM   #12
bishopts
bishopts's Avatar
7000. It was before i had even looked into the tune. I moved it to 6600. My guess is the momentum it built was faster than its response. The freeze frame data for the miss was 7400.
Old 05-12-2026, 05:51 PM   #13
KingLT1
KingLT1's Avatar
It must have been tuned then because the rev limiter on these cars stock is 6600rpm.
Old 05-12-2026, 06:04 PM   #14
bishopts
bishopts's Avatar
Yea it was setup for e85 when i got it
