![]() Drives: 17 camaro ss Join Date: Mar 2018
Aftermrket fuel pump
Hey everyone I was looking at getting a LT4 fuel pump and ran into this pump. that Nostrum Energy 1050-250. I emailed the place I found it and they said "they are extremely tricky to tune". So I'm wondering if anyone here has used this pump or heard of it and knows anything about it.
https://sdparts.com/i-24532016-nostr...nergy+1050-250 |
#2 | |
Moderator
#4 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
I can help guide you toward your goals. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#5 | |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
I got Nostrum injectors on mine. It took time and love in the tuning process but they idle and run just as good as the factory injectors.
758 HP/ 804 TQ |
Moderator
Have not found that to be the case with mine. Way too much time into them and got little support from the manufacturer. Maybe I’m just lucky LOL
#7 | |
Super Stock
I had to get the volumetric efficiency tables adjusted at the time, so this probably played into a factor of it, but did you try to adjust the injector fuel density multiplier table? That seems to be entirely the prevalent case in between making the injectors perform like factory ones do. There is no amount of support on their end which will get that set up for you. It takes a lot of time and effort to get it right. Probably more than most are willing to put in, but with that precise level of control of them you're more likely to wind up with much more precise fueling across the entire RPM band spectrum, this winds up showing up in the fuel trim stability throughout.
758 HP/ 804 TQ |
#8 | |
Moderator
#9 | |
Super Stock
Sure thing brotha, just let me know! I forgot you have an LT1 so there's already a discrepancy that I didn't account for. You'd be surprised what they don't include in their applicator templates. There's more layers to it than they lead you to believe just based on the parameter changes they give you.
758 HP/ 804 TQ |
