Old 04-27-2026, 07:10 PM   #1
Whoomba
Question for my techie mech friends
Really, will any mod that doesn’t require a tune make hardly any difference?
Old 04-27-2026, 08:24 PM   #2
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Mamo throttle body. It makes the throttle response more crisp and wide open throttleflow volume is better.
Better tires make a big difference. Cant go fast if your spinning all the time.
Cold air intake isn't enough gain to justify the price.
Headers are more of a headache because the codes that need to be delt with and again the price per gain doesn't justify it since the stock headers are a really good design already.
Catback or axle back is justified if you understand it's not a performance gain but more of a personal enjoyment gain.
The most cost effective gain that requires a tune would be e85.
Old 04-27-2026, 09:50 PM   #3
SpartanSS
Drives: 2023 Camaro 2SS
Basically what Bishop said… the Mamo v3 TB is definitely worth it but otherwise tires and maybe also BMR cradle bushings too since they clean up a lot slop from wheel hop
SpartanSS is offline   Reply With Quote
Old 04-27-2026, 10:47 PM   #4
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I agree... I went from 275's out back to 305's and ditched the runflats, made a world of difference! From spinning all the time to finally being able to hook...
I have the Mamo V3 TB, I agree as well, improved throttle reasons and crispness and allows more airflow at full throttle...
Old 04-27-2026, 11:53 PM   #5
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Drives: Black 2023 ZL1 A10
2 Stupid(I suppose) follow up questions.
For my 2023 ZL1:
1) Does the Mamo V3 Throttle Body require/NEED a tune?
2) Is it easy to install?(I need Kindergarten level of install difficulty or I won't change anything out)
Thanks!
2023 A10 ZL1 "NYTMARE"
NYTMARE23 is offline   Reply With Quote
Old 04-28-2026, 12:13 AM   #6
2SS Capt
2SS Capt's Avatar
For my 2023 ZL1:
Thanks!
No tune required, it is literally 4 bolts, stupid easy to install... Pre-school level... Just don't get stupid and over-tighten the bolts...
It is really a complete "No-Brainer" of an add on... Use a 1/4" drive rachet and make them good and snug, you won't over-torque them with a little 1/4" drive rachet...
Old 04-28-2026, 12:58 AM   #7
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Thank you! Sounds good. I'll definitely save up and try to get one then!. Any good deals/websites in particular to get one from?
Old 04-28-2026, 06:43 AM   #8
Annihilate
Annihilate's Avatar
Drives: 2024 2SS Camaro, 1988 IROC Z
Send a message via Skype™ to Annihilate
I'm hoping there will be a memorial day sale...
2024 2SS Camaro, Riverside Blue Metallic, NPP, F55, CF5, 5ZZ, VTU, S0O, 5KP, JF5, 2nd Gen GFX
Annihilate is offline   Reply With Quote
Old 04-28-2026, 07:08 AM   #9
bishopts
bishopts's Avatar
For my 2023 ZL1:
Thanks!
https://www.camaro6.com/forums/showthread.php?t=636067
I did a step by step for the SS. It should be pretty much the same thing.
Old 04-28-2026, 07:28 AM   #10
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Good point! I'll keep my eyes out for that as well! Thanks!
Old 04-28-2026, 07:32 AM   #11
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Thank you for that!. Definitely will help.
Old 04-28-2026, 08:59 AM   #12
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Depends on how you interpret this, what you're trying to do and if it's worth it to you.
A lighter wheel+tire setup. I knocked off an honest 30lbs of rotational mass + drag radials for traction, no tune.
A light weight battery. I knocked off 30lbs, no tune.
Rear seat delete. Knocked off another 30lbs, no tune.
I don't have personal info about it but like others said the Mamo TB, no tune.
Other more sound oriented stuff like axlebacks+X pipes that delete the secondaries, no tune.
Can we count the range device? V8 all the time, no tune.
I'm a fan of the stock airbox unless you like driving with your hood open, opps who said that
Lethal did a dyno test with a K@N filter and gained 4-5hp, no tune.
As far as making tons of power without a tune? Hell no. Even if you start making enough power on the stock tune the throttle blade will damper it down if I understand it correctly.
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is online now   Reply With Quote
Old 04-28-2026, 07:49 PM   #13
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
Capt is referring to me. Torque for those 4 bolts is 88 IN-lbs (which is approx 9 ft-lbs), not 88 FT-lbs. I didn't even make it to 88 before something snapped. Incredibly lucky for me, it was the bolt and not the mount.
My Camaro Journal
Old 04-28-2026, 08:49 PM   #14
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Bro...
758 HP/ 804 TQ
