Old 04-25-2026, 03:19 PM   #1
Steve65
Drives: 2013
2020 Bose Door speaker out Please help
Door speaker hissing and humming. Crutchfield recommended a replacement same problem. I replaced with Bose oem out of 2019. Same problem....is there any solution. I assume I can order a new oem from dealer...not sure of that cost.
Steve65 is offline   Reply With Quote
Old 04-25-2026, 03:29 PM   #2
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
If you keep replacing the speaker and the issue remains, then you have an internal issue happening within your amplifier. You may want to try a used one or borrow one off someone to confirm it's the issue. Based on what you're describing though, that is most likely the issue.
758 HP/ 804 TQ
ZLRob is online now   Reply With Quote
Old 04-27-2026, 08:54 PM   #3
p47dman
Drives: 2024 Camaro 1SS
I might guess wiring issue. Check at door joint.
p47dman is offline   Reply With Quote
Old 04-27-2026, 09:34 PM   #4
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Radio could be failing too. Try fading the sound to the back and balance to the opposite side to see if the noise persists.
bishopts is online now   Reply With Quote
