Old 04-18-2026, 03:45 PM   #1
HyperMike
Drives: 2018 Camaro 2SS 1LE
Just Bought a Procharger and Headers, Tip/Advice
Hi all,
So as the title says, I just bought a Procharger Stage II Intercooled kit with a P1X, and Kooks 2" long tube headers, with hi-flow cats. For supporting mods I have bought the LT4 HPFP, Granatelli wires, wide band, and a banks gauge.
I plan to install myself around mid may. Just wondering for those who have done it, any advice, tips, or tricks.
Its going on my 2018 2SS 1LE no other mods done.
Thanks in advance.
HyperMike is offline   Reply With Quote
Old 04-18-2026, 04:47 PM   #2
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
A JMS bap would help with the lowend if you decide to go with some e85. Other than that good start.
d1sc w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, mamo ptb, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
WiggyB is offline   Reply With Quote
Old 04-18-2026, 08:15 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by HyperMike View Post
Hi all,
Thanks in advance.
LT4 injectors and a flex fuel sensor should go on too. Not to mention one step colder plugs as well.
Old 04-19-2026, 10:51 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
You need full fuel system not just injectors.
Colder plugs as Josh mentioned. NGK 7 or Brisk 14
Proper crank case ventilation.
Octane. Pump gas alone isn't enough unless you plan on running low bost(6-7psi). You are adding boost to a high compression engine with very tight ring gaps and marginal strength pistons. Ethanol works well here but many areas do not have it. Other options would be alky injection or install a cam to bleed off some dynamic compression.
Old 04-19-2026, 08:30 PM   #5
HyperMike
Thanks folks. No E here in Winnipeg, closest is across the border in North Dakota so sticking with 93 oct.
I also ordered a Might Mouse catch can too.
Old 04-19-2026, 09:51 PM   #6
Joshinator99
Moderator
Then keep the boost modest… or don’t and we can give you advice on rebuilding the bottom end.
Old 04-19-2026, 10:26 PM   #7
Party pooper!
Old 04-27-2026, 11:25 AM   #8
HyperMike
Hi another quick question, I assume i will need a new MAP to read the higher pressure right? What do you folks recommend? I am doing my own research but figured would ask to help validate what i find out. So far i am seeing GM P/N 12592525 would that be right?
2018 Camaro 2SS 1LE Hyperblue. Mods: Procharger Stg II Intercooled System with P1X, Kooks 2" Long Tube Headers, Hi Flow Cats, LT4 HPFP, Might Mouse Catch Can.
Old 04-27-2026, 11:30 AM   #9
KingLT1
KingLT1's Avatar
Seems like the Procharger guys run the LS9 3 bar map.
Old 04-27-2026, 12:46 PM   #10
HyperMike
Sweet ok thanks.
