Old 04-17-2026, 10:53 PM   #1
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Obscure retainers for engine wiring harness
I'm sure I'm not the only one who has run into issues here but I have searched high and low for retainers and clips that broke during my engine rehaul. There were a few different ones that broke on me. Two being the ones for my radiator fan harness and main clip that ties onto the shroud. There was also one that broke on my valve cover which was a zip tied fir tree which holds the harness in place there. Hit up the dealer and of course they hit you with the "Oh GM sells it as an assembly so if you break it you need to buy the assembly." Line of crap.
Anyways, for anyone who ever runs into this issue, I found the suitable replacers and the company who makes them. These obscure retainers and clips are made by HellermanTyton and the retainers are obtainable via Digikey and Amazon.
Part numbers are as follows:
155-30702 Connector retainer clip w/ fir tree attachment
Name:  fir tree clip.jpg
157-00150 Harness cable tie clip w/ fir tree attachment
Name:  fir tree shroud clip.jpg
The only one I've had trouble finding a one for one replacement is shockingly the most simple one of the bunch which is the umbrella fir tree stanchion with the zip tie directly above it. That being said, however, they are obtainable on Amazon buying a variety pack of automotive fasteners, usually in the 60- 80 pack range. Needless to say I have no part number for this one, but here is a visual of what it looks like.
Bonus: these are the clips for the two front supercharger harness zip ties that fasten to the top of the lid bolt/ stud combo fasteners
157-00233
I hope this helps someone!
758 HP/ 804 TQ
Old 04-18-2026, 06:27 AM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Great info! Thanks!
Old 04-19-2026, 10:56 PM   #3
GreenZLE
Drives: 2020 Rally Green ZL1-1LE
THANK YOU!!!!
GreenZLE is offline   Reply With Quote
Old 04-20-2026, 05:39 AM   #4
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Heck yeah! Now I can get rid of about 800 zip-ties !!! Great Info !
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 04-20-2026, 09:15 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
GREAT idea!!! Those are a PITA to find, so thanks for sharing!!!
'20 ZL1 Black "Fury"
Old 04-20-2026, 10:53 AM   #6
ZLRob
Super Stock
ZLRob's Avatar
I'm not here for a long time. Just a good time gents.
758 HP/ 804 TQ
