Old 04-08-2026, 09:37 AM   #1
race24x
Drives: 80 Z28 - 93 Z28 - 14 Camaro SS-RS
HP gains from 2.3 upper pulley and Big Gulp
Has anyone tried just a couple mods like this and what gains did you get? I am thinking of doing the 2.3 upper and a Big Gulp. Eventually I would have ,y blower ported 103mm TB as well, but not this year. No headers yet but I do have an axle back exhaust.
1980 Z28 AWSM-Z
1993 Z28 AWSM-Z
2014 2SS AWSM-SS
2018 ZL1 AWSM-Z
race24x is offline   Reply With Quote
Old 04-08-2026, 09:59 AM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
20-25whp, Big Gulp will require a tune though.
Old 04-08-2026, 10:48 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
All a pulley will do is increase power on the first hit, then the blower is hot enough that you lose the added power because IAT is up in a range where timing will be pulled to keep from getting knock retard. Adding ethanol fixes a lot of short comings from the cooling side of the stock blower. Your best bet if limited to 93 octane is to do Intake, headers, ported blower. Gain power through efficiency improvements...not by forcing more hot air through a system that is limited by cooling and flow restrictions.
Old 04-08-2026, 12:23 PM   #4
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Spot on.
OP pulleys are a waste of time on an otherwise stock set up OP because all it does is heat up the blower and the stock set up is already maxed out in the configuration it is in. You will create a lot of knock and the engine will pull timing then rob you of even more power.
It's a vicious cycle on these set ups, so it's best you make the effort to tune, switch to ethanol which will allow the engine supercooling AND THEN you can start changing out pulleys. If ethanol fueling is not available then the best thing to do are airflow efficiency upgrades. Cam, ported or larger blower, etc. But you don't want to spin the blower faster in your current configuration.
Basically everything that King said.
758 HP/ 804 TQ
Old 04-08-2026, 11:13 PM   #5
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Hey buddy, do you have access to E85?
Old 04-09-2026, 10:33 AM   #6
race24x
No E85 in Maine unless I buy it by the can or barrel.
I was hoping that naturally cool temps in Maine would help me with the IAT temps as there is really only about 4 weeks of real summer LOL
So I probably shouldnt bother to change the pulley just a good CAI for now? If I get the blower ported and 103 TB I read that changing the pulley to a 2.3 then restores some of the low end torque and power that gets moved up in the RPMs by the porting?
1980 Z28 AWSM-Z
1993 Z28 AWSM-Z
2014 2SS AWSM-SS
2018 ZL1 AWSM-Z
Old 04-09-2026, 11:27 AM   #7
ZLRob
Super Stock
ZLRob's Avatar
There are currently two popular types of port jobs available. One is the Kong and the other is Jokerz. The one that requires a pulley down to restore low end power and is the Kong race port. The Jokerz full tilt does not have that problem.
Do with that information what you may.
758 HP/ 804 TQ
Old 04-09-2026, 12:56 PM   #8
race24x
Thank you for that
1980 Z28 AWSM-Z
1993 Z28 AWSM-Z
2014 2SS AWSM-SS
2018 ZL1 AWSM-Z
Old 04-09-2026, 02:39 PM   #9
SOCAL.M6.ZLE
Lots of advantages to running E85, but only if it is accessible.
The paired logic is that if you are going to invest in tuning (either remote or in person) it's best to get your moneys worth, so prevailing thought be to bundle your first round of mods (Headers / Big Gulp / E85 etc...) to get a better value out of the time / cost of tuning.
Note, Porting the blower will help even on a stock motor. LMP has shown over 50rwhp on an otherwise stock blackwing...
Myself, gained 60rwhp + 5rwtq when going from a standard port to an Xport. Note; although I did not loose torque, it did move peak torque up from a peak of 3,500 to 4,500 rpm. Also not, some of the 60rwhp gain was from fixing a belt slip issue.
Old 04-09-2026, 05:54 PM   #10
TurboC3
TurboC3's Avatar
Drives: 23 ZL1, 08 C6 vert, 70 Skylark GSX
This is similar to my, currently 93oct, under warranty plan. Stage 1..x-port & 107tb, no tune. Stage 2..add a lower pulley, E85 and a tune. Is this a good plan? Don't want headers, trying to keep it as stock as possible...lol.
TurboC3 is offline   Reply With Quote
Old 04-09-2026, 08:39 PM   #11
ZLRob
Super Stock
ZLRob's Avatar
Not a good plan. You do not change any airflow characteristics on this vehicle without needing to compensate for it within the calibration file itself. You will either be losing power from going lean, and/ or creating knock which will rob you of power due to timing pull, which is dangerous due to the fact that if you do it a lot you can grenade the engine despite forged internals in the LT4, so you'll either be making the same or quite possibly even less than what you make right now despite the extra mods. Just to give you an idea, despite all of my mods, I still only make 585 on 91 octane fueling (it's the most available fuel around where I am) and then as soon as I fill it up with pump E85 I go all the way up to 758, which is absolutely stupid from a power delivery standpoint, but those are the limitations of the standard gasoline fueling where I am. Is what it is I suppose.
Save yourself the trouble and get the mods you want on it, then tune for it. Just know if you do a pulley, a ported blower, and try to run E85 on it you will definitely not be able to run pump.
The mods in my signature, they're not on accident or just because I wanted extra fueling headroom. I was forced into it because in order to run ethanol the fuel system demands at least 30% more fueling over standard octane gasoline.
758 HP/ 804 TQ
Old 04-10-2026, 06:08 AM   #12
red6.2
Drives: 2010 camaro
best bet for you sounds like 100oct, long tubes and rotofab. its funny because you will end with a faster car with just a e85 tune. This will piss off many but its the truth.
red6.2 is offline   Reply With Quote
Old 04-10-2026, 08:51 AM   #13
cajunzl1
Drives: 2018 ZL1
My 2018 ZL1 with a 2.3, ported TB, Std Rotofab and E55 did an easy 655 and had issues with tire spin on the dyno. Stock Blower and Stock Exhaust.
I do have the LMP heat exchanger and ADM expansion tank, IAT's would start to creep up after back to back to back pulls, but on street no problem with the temps and casual pulls.
E85 really helps.
cajunzl1 is offline   Reply With Quote
Old 04-10-2026, 03:31 PM   #14
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
You do not need the extra flow of a Big Gulp at this point. Not even close. Headers, tune, lower/upper pulley and SC ported, tune. THEN a Big Gulp makes sense.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
