![]() Drives: 2024 Camaro 1SS Join Date: Mar 2024
Intake needs
What all is needed to install LT2 intake? I assume it has o rings, not paper gaskets. Vacuum fitting. What have you used?
Covers that may fit? Fuel rail covers? Are any adapters needed to hook up TB with a CAI already installed? K&N. Any wiring extensions or adapters needed? The bolt ons that I may do I want to be easily removed so I do not void warranty if needed. Thanks |
![]() Drives: Camaro SS 1LE M6 Join Date: Feb 2024
Buy it from GPI, for $70 extra or so they provide the brake booster adapter and shaving to fit the fuel pump. Gaskets you can reuse the ones from your lt1 or get new ones. It will connect to your cai just fine, I have a rotofab. You’ll also need a map extension harness. For covers, the only true plug n play option is the corvette lt2 cover. Fuel rail covers you’ll have to do some modifications to get them to fit.
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold |
ok
Will GPI porting package be beneficial on the LT2?
![]() Drives: ‘16 M6 1SS fbo/cam Join Date: Apr 2026
Currently on the GPI ported lt2 set up, I’m running the Katech adapter and an lt5 tb but the stock tb will bolt right up to it other than that it should be the booster vac fitting and map extension
16’ M6 1SS 1/4mi car
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
I was surprised at how flexible/fragile the intake manifold gaskets on our engine are and would recommend a new set when changing the IM. Fortunately
Amazon has a set at a very good price- https://www.amazon.com/Dtomi-Manifol...zcF9hdGY&psc=1 Have fun and don't over-tighten p47dman!
#7 |
![]() Drives: 2011 GMC Sierra 1500 Join Date: Jun 2022
Given that the gaskets are fragile, HARD PASS on an Amazon set from CHINA to save money.
Your money, your car so get what you want. I just purchased an OE set from Summit today.
2023 LT1 M6 Coupe - Black (GBA) on Black (H1T) - Build Date: 8/22
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W) LT1 PBC engine - Shane Parker Current mileage: 400 |
#8 | |
#9 |
2020 Shadow Gray 2SS
Can you install an LT2 intake without a tune and get HP gains? If so, how much?
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#10 |
Yes, have Mamo installed onLT1 intake already. Are the o rings the same between the 2 manifolds?
#11 | |
Applications for ACDelco Throttle Body Gaskets 12639086 So the plan is to run a CAI, Mamo v3 TB and a LT2 intake with the stock tune? I am curious to see how that combo turns out. I went a little different route with a Mamo TB/Intake combo since I wanted to keep the stock look and tune for warranty purposes. Going to do the swap when I get some free time in the week or so hopefully. Keep us posted p47dman!
