![]() ![]() ![]() ![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
Properly diagnose your vehicles.
This is just a recommendation from a currently employed diagnostic tech.
Its coming up on April right now. I work on several cars per day and I've replaced 0 MAF sensors. So before every one of you get a cookie cutter diag from the internet that suggests to replace you MAF sensor. You probably want to dig further. You guys know i check the repair threads quite a bit and none of you replace a MAF and your problem is gone. Its always still acting up and you have to figure out something else. P0171,p0174, p0300's, p0011's. Being fixed with a MAF, you are more likely going to be hit by lightning. Im not saying MAF never fail, I'm just saying it shouldn't be your first guess. |
![]() Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
Hooray for information dumps. If I have the need to google this in the future, thank you.
#3 | |
2020 Shadow Gray 2SS
But what is the most common cause of these failures??? Can you give some guidance on resolving these codes???
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#4 | |
p0171 and p0174 are vacuum leaks mostly. P0011 p0014 p0017 are usually lack of oil and pushing your oil changes too long. Which has streached the chains and beat the cam phasers to death. P06de is the oil pump pressure control valve. P0128 is a thermostat P0299 is tricky, sometimes its a turbo but usually its a boost tube is cut Last edited by bishopts; 03-24-2026 at 07:11 AM. |
![]() Drives: 1987 IROC, 2020 ZL1 Join Date: Nov 2023
Thanks for sharing this information!!
Always appreciate it when someone shares their expertise and knowledge |
