Old 03-19-2026, 08:36 PM   #1
NewCamaroGuy2018
2022 Vivid Orange ZL1 1LE
Drives: Firebirds - 1970,1974,1997,1999
Angry 2022 ZL1 1LE power steering reservoir
Where is the PS reservoir located? In addition to my two other unresolved problems, the PS intermittently dies on a cold startup. There is no steering!!! Have you tried steering 305 front tires with no power? There is steering after a few moments, then all is well. There are no DTC codes. Dealer labor rates are $325. Thanks for any advice.
2022 ZL1 1LE with CALLOWAY SC750
6 speed manual
Vivid Orange Metallic
30+ road track days
NewCamaroGuy2018 is offline   Reply With Quote
Old 03-19-2026, 08:43 PM   #2
piening2150
Drives: '23 2SS 1LE 6MT
No reservoir. It's electric.
piening2150 is offline   Reply With Quote
Old 03-19-2026, 09:14 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Yep, this. Never have to worry about fluid, lines, overfilling/underfilling, etc
Old 03-20-2026, 02:00 PM   #4
NewCamaroGuy2018
Thanks guys. Now I have an electrical problem!
Bob
Old 03-21-2026, 09:25 PM   #5
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Bob
Probably a fuse. Jumping it off will cause that sometimes.
Or if a new battery was installed the bolt for the power steering wire could have been left off or loose.
Open the hood and look down. Just under the belt is a cylinder looking thing. That's your power steering motor. Make sure its plugged in and no wires are chewed up.
power steering failure
