Old 03-18-2026, 07:26 PM   #1
dwlissick
dwlissick's Avatar
Drives: 2020 Camaro SS
need information about the 10 speed in the SS
I am new to this forum just started today actually you can link me to the existing thread if there already is one. I just want to know info about the 10 speed transmission in the 2020 Camaro SS. technical info, reliability, anecdotal info blah blah blah. I'm curious because this is my firstcar that's not a manual and I don't know much about these automatic i am confused on why it has 10 gears and if that's necessary someone give me a rundown please
dwlissick is offline   Reply With Quote
Old 03-18-2026, 08:08 PM   #2
2023-SS
Drives: 2023 SS
one of the Corvette engineers said "they could do everything they needed with four forward gears" but the number of gear was driven by euro trash getting a bunch of gears.
I really miss being able to bark second gear like a four speed auto!
7th gear is 1:1
if you put it in TRACK & manual, it will NOT over rev & blow the engine, it say "down shift denied" or something.
it's fun to open the NPP & paddle shift.
and WOT runs sounds funny, just BRAP BRAP BRAP
but at the end of the day, it does good on MPG and seems to handle the power, and it is fun with paddle shifting.
2023-SS is offline   Reply With Quote
Old 03-18-2026, 08:14 PM   #3
Hi dwlissick and to the forums, again
When prompted in sufficient detail, I find Grok's responses useful and rarely mistaken. Below is what it said about the 10L80 that is in your Camaro.
My only comment on the AI's output is that it exaggerated the scope of reliability issues, yes, the 2nd generation of this transmission has had valve body issues, but yours is likely still from the 1st generation, and, at least based on comments and threads on this forum, the Camaro is much less affected by it than GM trucks.
In general, the more gears and especially the more overdrive (past 1:1) gears an automatic has, the better its fuel economy and smoother its power curve, but it'll also increasingly feel like it's shifting "all the time".
Finally, you will find this thread a useful source of technical information: https://www.camaro6.com/forums/showthread.php?t=584316
Prompt:
"give me a rundown on the GM 10L80 transmission, including technical specs, anecdotal and statistical reliability and a summary of advantages and drawbacks compared to the Tremec TR-6060 manual transmission in high horsepower applications"
Response:
he GM 10L80 (part of the Hydra-Matic 10LXX family) is a 10-speed longitudinal automatic transmission co-developed with Ford (their version is the 10R80). It debuted around 2017–2018 and is used in GM rear-wheel-drive and AWD performance cars and trucks, prioritizing wide ratio spread for both acceleration and efficiency.
Technical Specs
  • Type: Electronically controlled 10-speed automatic with 3 clutches, 2 brakes, and 4 planetary gearsets (triple-clutch intermediate shaft design for compactness).
  • Gear Ratios (standard 10L80; slight rounding variations in sources):
    • 1st: 4.70 (precisely ~4.6957:1)
    • 2nd: 2.99 (~2.9851:1)
    • 3rd: 2.15 (~2.1462:1)
    • 4th: 1.77–1.80 (~1.769:1)
    • 5th: 1.52 (~1.5201:1)
    • 6th: 1.28 (~1.2751:1)
    • 7th: 1.00
    • 8th: 0.85 (~0.8536:1)
    • 9th: 0.69 (~0.6892:1)
    • 10th: 0.64 (~0.6357:1)
    • Reverse: ~4.87
  • Overall Ratio Spread: 7.39:1 (wide for strong launches + low-RPM highway cruising).
  • Torque Capacity: Nominal ~590 lb-ft (800 Nm) for the base 10L80; the related 10L90 variant (higher-performance) is rated up to ~664 lb-ft (900 Nm). Stock applications often pair with 420–650 hp engines (e.g., 6.2L V8s), but torque management software limits output in some calibrations.
  • Other Notes: Uses Dexron HP fluid (exact capacity varies by application, typically 10–12 quarts total with converter). Produced in Romulus, MI (and Mexico). Applications include 2019+ Silverado/Sierra 1500, Tahoe/Suburban/Yukon, Camaro SS (some ZL1 use 10L90), and related Cadillac models. It replaced the 8L90/6L80 in many platforms for smoother steps and better efficiency.
Reliability (Anecdotal and Statistical)
Stock reliability is mixed — generally good in lighter-duty or performance-car use but plagued by issues in trucks/towing. No comprehensive public failure-rate statistics exist (GM doesn’t publish them), but real-world data points to widespread valve-body problems.
Common issues (from rebuild shops, forums, and GM service bulletins/recalls):
  • Harsh/delayed shifts, shift flares, or “gear hunting” (valve-body solenoid retainers, sticking valves, or software).
  • Torque-converter shudder/lockup clutch wear (especially towing or stop-go traffic).
  • Overheating under sustained load.
  • In severe cases: sudden rear-wheel lockup at highway speeds (due to hydraulic pressure loss).
GM response: Multiple recalls and extended warranties (some to 115k+ miles) for valve bodies in 2020–2026 trucks/SUVs and certain Camaros/CT4/CT5. Updated valve bodies and TCM software are the fix, but backorders and repeat failures have been reported into 2025–2026 models. Parts shortages have left some vehicles sidelined for months.
Anecdotal feedback:
  • Trucks (Silverado/Sierra/Tahoe towing): Frequent complaints of failures at 20k–60k miles; shudder and harsh shifts common even at low mileage. Some owners report 100k+ trouble-free with fluid changes and no heavy towing, but valve-body swaps are routine.
  • Performance cars (Camaro SS/ZL1): Much better reputation — many high-9s drag passes with mild tunes and few issues reported on Camaro6 forums. Stock units often last 50k–100k+ with proper maintenance.
  • High-mileage successes exist, but the transmission’s complexity (electronics, tight tolerances) makes it less forgiving than older 6-speeds. Rebuilds or upgraded units (new valve body, billet converter, upgraded clutches) dramatically improve longevity.
Overall: Solid design when maintained or built correctly, but factory valve-body and software issues have led to recalls affecting hundreds of thousands of vehicles. It’s not “bulletproof” out of the box like a 4L80E, but aftermarket fixes exist.
Comparison to Tremec TR-6060 Manual in High-Horsepower Applications
The TR-6060 is a 6-speed manual (used in C6/C7 Corvette, 5th/6th-gen Camaro, CTS-V, Challenger Hellcat, etc.). Stock torque rating 430–650 lb-ft (depending on gearset; lower 1st gear = sometimes lower rating). Wet weight ~146 lb. Helical gears, triple-cone syncros on 1-2, double on others, aluminum case. Multiple ratio sets available (e.g., Camaro SS often ~3.01/2.07/1.43/1.00/0.84/0.57 or 2.66 first-gear variants).
In high-horsepower scenarios (700–1,000+ hp/tq drag, street, or track builds):
Advantages of the 10L80 automatic:
  • Much quicker, consistent shifts (especially with TCM tune/paddles) — big ET advantage in drag racing.
  • 10 gears = tighter ratio steps for optimal powerband use and better launches via stall converter.
  • Easier to drive daily or in traffic with massive power; no clutch-pedal fatigue.
  • Built versions (upgraded valve body, billet converter, clutches) routinely handle 1,000+ hp reliably and dominate modern drag classes.
Drawbacks of the 10L80:
  • More complex/expensive to diagnose/fix (electronics, valve body).
  • Heat buildup and fluid management critical under hard use.
  • Stock torque management can cut power; requires tuning.
  • Heavier overall and more prone to the valve-body issues noted above if not upgraded.
Advantages of the TR-6060 manual:
  • Simpler mechanical design = cheaper rebuilds and higher inherent reliability (main wear item is usually the clutch, not the trans itself).
  • Direct mechanical link (no fluid coupling losses or torque management).
  • Lighter weight and excellent shift feel when warm.
  • Proven in 700–900+ hp street/strip builds (TREMEC Magnum/TR-6060-based aftermarket units push 1,000+ lb-ft).
Drawbacks of the TR-6060:
  • Clutch slippage/wear is the limiter at very high torque (needs upgraded clutch/flywheel).
  • Shift times are driver-dependent and slower than a well-tuned auto → hurts drag ETs.
  • Only 6 gears = bigger steps, less optimal acceleration in some setups.
  • Harder on the driver in traffic or with 1,000+ hp on the street.
Bottom line in high-HP use: For pure drag racing or consistency, a properly built 10L80 wins on shift speed and launches. For road racing, purist street driving, or lower-cost builds, the TR-6060 (or Magnum upgrade) is simpler, more engaging, and often just as durable once the clutch is sorted. Both transmissions are strong when upgraded — the 10L80’s extra gears and auto convenience give it the edge in modern high-HP drag performance, but the TR-6060 remains a favorite for its mechanical simplicity and lower long-term ownership hassle.
If you’re building a specific setup (drag, street, towing, etc.) or have a target horsepower, I can dive deeper into recommended upgrades for either!
Old 03-18-2026, 10:20 PM   #4
dwlissick
dwlissick's Avatar
You're the best bro
Prompt:
Response:
Old 03-18-2026, 10:51 PM   #5
Originally Posted by dwlissick View Post
You're the best bro
My pleasure, Sir
Old 03-20-2026, 11:33 AM   #6
2023-SS
Drives: 2023 SS
another good read:
https://gmauthority.com/blog/gm/gm-engines/lt1/
