![]() Drives: 2022 Camaro SS 1le Join Date: Dec 2025
Best fuel type stock engine
I understand 91 octane is the recommended octane for the car but I'm curious about running non ethanol fuel as that is an option at a couple of my local stations. Am i better off sticking with the non ethanol, or are there any downsides?
OSCM(SW) USN Ret.
Drives: 2023 Camaro 2SS-1LE VOM 6M Join Date: Apr 2023
I use 93 O and Top tier gas only. Was using Sams 93 but got wise and shifted to top tier. Hope ur running a catch can. M2C's
2023 2SS-1LE VOM, 6M, SR S-TBrace, A-PDL's, Fuzzy suede KP's, NAV
1100 3/29/23 2000 3/30/23 3300 5/1/23 3800 5/4/23 4200 6/1/23 6000 6/6/23 |
![]() Drives: '23 2SS 1LE 6MT Join Date: Oct 2025
Costco 93 is always the cheapest around here, it's Top Tier, and I get enough cash back from Executive Membership to pay for itself. Win x3.
#4 | |
![]() Drives: 2023 Camaro Convertible ZL1 A10 Join Date: Mar 2023
And the prices you see are not up to date. we pay almost $6 a gallon for regular 87 right now
ZL1/1LE Convertible Project Car
You don't want your LT1 engine to see anything below 93 octane, otherwise your ECM tune will drop down to its low octane table, the engine will lose some power and be more prone to detonation. Don't do it. If you can only get 91, then sure, use that (and curse your state for not offering you at least 93), but 87 should be out of the question.
100% 93 octane is a unicorn, I've never seen it at any gas station, so I'd suggest that you stick with regular 93 that has 10% ethanol. The car is set up for this fuel. Running something with less ethanol will technically improve your fuel economy, but only a tiny bit, it's not worth the typical $0.90 to $1.10 surcharge. High octane race fuels will not help your engine much either: as long as the high octane table is being used and there is no knock, the engine is operating under ideal conditions, adding more octane while still running the stock tune doesn't help (it can even be inferior as it can slow down combustion).
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
#7 |
These engines will knock even on 93 octane with the stock timing maps. I usually end up around 23 degrees on cars with intake / headers and 93 octane... which is about 1 degree less timing than stock. This is why they pick up so much power on E85. The LT1 picks up about 25-30whp on E85. The older LS3 will only gain about 6-8whp. I know you didn't ask about E85 but I am trying to paint a clear picture why octane is important for this engine.
#8 |
![]() Drives: 2023 Camaro 1SS M6 Join Date: Mar 2023
Never seen non-ethanol gas here.
Part of the reason why I use stabilizer in the winter. Luckily we do get 93 though. V-Power it is.
Black 2023 Camaro 1SS Coupe M6
Ordered: April 2022-----Built: July 2022-----Delivered: September 2022 -Dual-Mode Exhaust (NPP) -Red Painted Calipers (J6F) -5 Split Spoke Bright Silver Painted Aluminum Wheels (56W) -Chrome Camaro Logo Fender Badge -Second Generation Front Splitter in Satin Black |
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
I mean 93 here is like toilet paper availability. We also have a common selection of E85 as well.
#10 |
Hot Camaro
#11 |
Guys, I do understand that E is better (I run it, too), but OP asked the question with regard to his stock engine and even specifically mentioned ethanol free gas. Chances are he isn't running headers or intake, much less a flex fuel kit with a tune, so 93 is what he needs.
The alternative is him spending a lot of money, which he didn't ask us about.
#12 |
#13 |
![]() Drives: Chevy Camaro ZL11LE Join Date: Jan 2026
Sunoco is now offering 94 Octane instead of 93 at most locations in New England. Not sure where else but easy to search here:
https://www.sunoco.com/find-a-station |
#14 |
![]() ![]() Drives: 2020 Camaro 2SS Join Date: Nov 2022
Wow, great info here. I thought that Premium 91 was good enough, and I've been running it for a couple of years. I will switch back to 93 Top Tier (Mobil/Exxon in my area) immediately!
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
