Old 03-07-2026, 09:42 AM   #1
len125
Drives: chevrolet camaro
coolant flush
how much is a camaro V6 basic drain and fill coolant flush?
len125 is offline   Reply With Quote
Old 03-07-2026, 12:46 PM   #2
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Depends on who does it. Its cheaper if you do it unless you break everything because you don't know how.
Dealerships are usually more expensive than independent shops.
Mobile mechanics can save you money sometimes but they can also have no idea what they are doing or maybe think they know what they are doing (which is much worse).
For the most part asking how much a coolant flush i ln your area on camaro forums isn't a good idea. Call a couple dealers near you and get quotes, then look on google maps for auto repair shops near you and look at their reviews. Then get quotes from them.
Old 03-07-2026, 01:04 PM   #3
sscentex
Drives: 2016 Camaro SS
Gonna be a couple hundred bucks at a shop. Worth it to avoid the mess and hassle.
2016 Camaro SS A8
Borla ATAK
Tuned
Drag DR77 Wheels
sscentex is offline   Reply With Quote
Old 03-07-2026, 07:35 PM   #4
S.Macias
Only6Cylinders
S.Macias's Avatar
Drives: 2016 Camaro V6 1LT
In my opinion it’s easier and cleaner to do than oil.
Only need a gallon and a half so can be done for about $30 ($28 for the coolant- not diluted, and $2 for a gallon of distilled water).
There’s the yellow valve on the passenger side, just twist. It’s a good arms length down on the side of the radiator. Capture the outgoing fluid. Close valve. Fill until full. Turn the car on with the coolant cap off for about ten minutes. Add any additional fluid. Good to go.
Instagram: @smaciasracing
S.Macias is offline   Reply With Quote
Old 03-07-2026, 08:29 PM   #5
Matt1LE
Matt1LE's Avatar
Drives: 2020 3LT Camaro 3.6L 1LE
Originally Posted by len125 View Post
how much is a Camaro V6 basic drain and fill coolant flush?
You can check to see if your dealer has any specials going on. It's getting into Spring. Nows the time they have cooling service specials. My V6 1LE, with extra radiators, was $130ish on a special deal.
I usually done that myself on many other cars and motorcycles. However, I had a C4 Corvette that had a the special cooling system I could never purge air out of the system no matter how hard I tried. That's why I didn't even bother with the 1LE and its cooling setup.
Good luck
Matt1LE is offline   Reply With Quote
Old 03-08-2026, 03:29 AM   #6
lowke
lowke's Avatar
Drives: 21 Camaro V6 manual
I replaced my thermostat recently.Drained the radiator and filled. Watched YouTube videos, made it easy.
lowke is offline   Reply With Quote
Old 03-08-2026, 11:55 AM   #7
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
Draining the radiator filling isn’t really flushing the cooling system which is what the OP asked about.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 03-08-2026, 12:51 PM   #8
bishopts
bishopts's Avatar
100%
Old 03-08-2026, 04:45 PM   #9
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
+1 it's not a flush but a "drain and fill" if you have a low mileage car, a drain and a fresh refill is easily accomplished as previously described- open the yellow valve, and remove the radiator cap (you are doing this with a cold engine, right?), I also took the cap off the little reserve tank on top.
Have your bucket under the drain and the car will very conveniently drain the radiator and all the little reservoir tanks up top.
Mix your Dexos coolant 50/50 with distilled water and slowly fill the radiator (you don't want to be in a hurry and trap any air, so pour it slowly). Then you will also need to refill the reservoir tanks, so have a funnel handy.
And you're done.
Take a drive and check your levels when hot. I changed my coolant based on the time factor (low-low miles for a car this age but) when she was about to turn 6 years old, I figured it was time. The fluid looked great (I had 25K miles on the clock) with nothing floating around or even cloudy, so it was my opinion that I needn't worry about a "flush". Can't remember if the car required any additional top off after driving, but if any was needed it wasn't much.
When she turns 10 I'll prolly do the same thing because it couldn't have been any easier and a lot less expen$ive then asking a dealer or any garage.
Ventmaster is offline   Reply With Quote
Old 03-12-2026, 04:05 PM   #10
wingchunsifu
wingchunsifu's Avatar
Drives: 2017 2SS A8, 2026 BMW X1 M35i
I just did mine in a well known local shop. They charged $170. The dealer will beat you over the head.
wingchunsifu is offline   Reply With Quote
Old 03-13-2026, 02:54 PM   #11
Ventmaster
Ventmaster's Avatar
LOL- just had to ask if this was a recent wound inflicted by a customer? Sounds fresh, like you may still be shaking your head over it.
But I especially liked the part about folks who "maybe think they know what they are doing"! I thought I was the only one who noticed that!
Old 03-13-2026, 03:25 PM   #12
bishopts
bishopts's Avatar
Ive seen it quite a few times. Recently a guy had a starter going out. He took it and said he can do it himself. Less than 24hrs his wife called and said she told him to take it back and let us do it because she needs it to work after it is repaired.
Old 05-26-2026, 11:33 AM   #13
LtColumbo
LtColumbo's Avatar
Drives: 2017 1LT RS V6 A8, 2020 Fusion
I've looked, but cannot find...info on block coolant drain plugs. I think most engines have them, but some are not accessible. What sense does THAT make?
What's the story on the LGX?
LtColumbo is offline   Reply With Quote
