![]() Drives: Chevrolet Camaro LT1 Join Date: Feb 2026
Join Date: Feb 2026 Location: Indianapolis Posts: 8 iTrader Rating: 0 reviews Alignment/handlings problems after repair. I was involved in a side swipe on my LT1 impacting the rear quarter panel, door, rocker, and rear wheel. The car bump steers like crazy, steering feel is uneven side to side with it being lighter to the left , and it just doesn’t feel connected to the pavement especially when making left turns. After each of my 3 alignments in the last month with totally decent numbers on the sheet when I left, I’d find the left front and back left toe was almost double the value (.10 to .20 or close to) after an alignment check. Last edited by xSHAKEandBAKEx; 03-10-2026 at 07:22 PM. |
![]() ![]() ![]() ![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
What suspension parts were replaced?
They did not replace any suspension parts. Simply pulled out the dent from the rear qtr panel and replaced the door.
Monterey County Camaros
Total toe for both front and rear seem a little high. Rear total toe for me is 0.1 degree (0.05 on each side) with front toe set to 0.
They may also need to reset the Steering Angle Sensor.
![]() ![]() ![]() ![]() ![]() Drives: 2012 Shelby GT500 Join Date: Jan 2020
What tires do you have?
2012 Shelby GT500 with VMP Gen 3R.
Prior: 2023 Camaro 2SS 1LE 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
Do you have FE3 suspension with it being an LT1?
I would think FE2. Could be using the wrong target numbers if that's the case |
#7 | |
I feel like the suspension on the left side is softer than the right. I can feel right front suspension behaving differently, giving more feedback, harsher but in the right way. The left side suspension seems less responsive and the car pulls left as well. Hope this provided better feedback. I feel like I have a bent “something” in there and to the body shop and dealer, it looks fine but they don’t know the car you know. |
#8 |
#9 |
Ive seen a dead rear shock make a car change lines on the highway from an even bump. The customer told me her car was dangerous on the highway, i went and drove it and came back and told her that thing is a deathtrap.
Ive also had a car that wagged like a fish on the highway and it was the bushing in one of the rear upper control arms. It wasn't really bad, just worse than the other side. |
#10 | |
I appreciate the feedback. I’m getting it inspected Monday so I’ll just take it easy on her until then. |
#11 |
To clarify for you the spring supports the weight. The strut just dapens the movement.
So if the spring isn't supporting the weight it will look squished down on that corner while it's just sitting there. But if the strut is bad, when you hit a bump evenly with both tires, the body will squish the bad side faster and more which will make it pull hard to that side. |
#12 |
![]() ![]() ![]() ![]() Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Bushings, a bad bushing will throw off your alignment. A good alignment guy should be able to tell you that. I have a 24 SS 1LE and have already replaced the front lower control arms due to bushing failure. I track mine though but I assume a accident can cause bushing damage.
