![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
AI going in hard on fueling and timing
AI leaning on physics and eng. theories and concepts and provided the following.
This isn’t what I’m running today but would be open to experimenting if there is a supporting consensus here. What are your thoughts? It seems really rich to me. I challenged that and it insists that it will make more power with these e85 RPM Target Lambda Timing (° Total) Notes 2,500 0.84–0.85 19–20° High load, knock sensitive 3,000 0.83–0.84 20–22° Torque ramp building 3,500 0.82–0.83 21–23° Approaching torque peak 4,000 0.81–0.83 22–24° Near peak torque 4,500 0.80–0.82 23–25° Peak torque area 5,000 0.80–0.82 24–26° Transition to HP focus 5,500 0.79–0.82 25–27° VE dropping slightly 6,000 0.79–0.81 26–28° Peak HP zone 6,500 0.79–0.81 27–29° Airflow limited, needs timing 93 octane RPM Target Lambda Timing (° Total) Notes 2,500 0.85–0.87 16–18° Knock-prone region, timing pulled back vs E85 3,000 0.84–0.86 17–19° Torque building safely 3,500 0.83–0.85 18–20° Approaching midrange torque peak 4,000 0.82–0.84 19–21° Peak torque area, conservative timing 4,500 0.82–0.83 20–22° Mid-high torque, slight knock buffer 5,000 0.81–0.83 21–23° Upper RPM, torque focus 5,500 0.80–0.82 22–24° Peak HP ramp 6,000 0.80–0.82 23–25° Peak HP, airflow limited 6,500 0.79–0.81 24–26° Top end, safe knock margin Humidity Fuel Humidity Effect Timing Change at WOT E85 High RH → cooler charge, ethanol adds knock margin +1–3° at 2,500–4,500 RPM 93 High RH → cooler charge, but less knock margin than E85 +1° max at 2,500–4,500 RPM E85 Low RH → slightly hotter charge 0 to -1° 93 Low RH → slightly hotter, more knock-prone -1–2°
Moderator
What combo is this being run on? Boosted or NA? Cam specs? Compression? What other mods? Sure as heck would not work on a boosted combo.
![]() Drives: 2022 Vivid Orange LT1-M6 Join Date: Dec 2015
I have tried numerous combinations using AI for timing and fuel that had a similar concept. All were slower (60-130) than what a tuner did. They say lower timing at peak torque, but it’s the part that was most noticeable when I made the adjustments. 2nd part was 110-120 and 120-130 mph segments when I tried .85 and below.
I spent way too much time with Claude,grok and chatgtp on this with little to show for.
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph |
#4 | |
I think I’ve tried and swept these afrs years ago and landed much leaner. I wish I kept my notes
#5 | |
#6 | ||
My tune is very similar to this car timing and fuel wise and you can see by rpm the afr/lambda and timing if you slow it down. The data log part starts around 15:45
