Old 02-18-2026, 01:45 PM   #1
vaeron
vaeron's Avatar
Passive Door Unlock Driver's Side not Responding
Okay I've searched everywhere and decided to wait to post about it until today. I've got my 2016 2SS, the passive door UNLOCK (edited, mistyped) works fine on the passenger side when attempting to enter the vehicle, but the driver side does not. Has anyone run into this issue? what was the fix? My first thought was the button not making contact or having a torn lead (haven't torn into it yet) but wanted to rule out anything else before I started pulling door trims to get into the door. Every other aspect of the locking / unlocking mechanism works. It locks fine automatically when I walk away, car starts normally every time. I have multiple fobs and replaced batteries in both. It is only the driver's side passive unlock that's not working.
2016 Black 2SS purchased in May 2025, 6 Spd.
GM Performance Strut Tower Brace, Mishimoto Oil Catch Can, MRR M017 wheels, powder coated in satin black, Continental Extreme Contact DSW06 285/30R20 in the front and 305/30R20 in the rear.
Last edited by vaeron; 02-20-2026 at 12:39 AM. Reason: mistyped and put lock instead of unlock.
vaeron is offline   Reply With Quote
Old 02-19-2026, 08:46 AM   #2
ember1205
Hot Camaro
ember1205's Avatar
Are you asking about Passive Door LOCK or Passive Door UNLOCK?
Passive LOCK allows the car to automatically lock the doors once both doors are closed and you walk away from the car.
Passive UNLOCK is a setting to determine whether just the driver's door unlocks when you press the button on the handle or if both doors unlock. I believe it can also be set to "OFF" which would seemingly make it so that NO doors unlock when you press the button (which doesn't make sense in my mind).
There is also the DELAYED Lock feature which allows the car to lock the doors after a single press of the Door Lock button on either door, no fob in the vehicle, and both doors closed for about five seconds. I use this feature on my Camaro, my current Silverado, and on my previous Silverado.
Old 02-19-2026, 09:25 AM   #3
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
I have to press the button on my car. I didnt know there was a passive function.
bishopts is online now   Reply With Quote
Old 02-19-2026, 02:37 PM   #4
SilverIce13SS
Drives: 2016 2SS
If I’m reading OP correctly, I’m having the same issue, even tho set to do so, the button on my driver door doesn’t always work, almost never on the first push, a couple times not even after four or five pushes. I more commonly now just go to the passenger door, which works fine and unlocks both doors, usually easier to put my backpack in the passenger seat that way anyway. (Just have to get to the driver side door before both doors auto-lock, which I have set also.) I just figured something was wearing out, but the work around wasn’t that horrible. (Key fobs work, just tend to not use them, not wild about sending a signal out into the world.)
SilverIce13SS is offline   Reply With Quote
Old 02-20-2026, 12:38 AM   #5
vaeron
vaeron's Avatar
Sorry, Unlock, I've messed with all of the settings on the head unit, nothing changes. I can get it to unlock on the passenger side using the button on the door, but not the drivers side. I've tried dozens of times to no avail.
My guess is it's probably a loose connection on the button or near the button on the handle but didn't want to tear the door panel off if y'all had other suggestions.
