Old 02-12-2026, 07:03 PM   #1
BoatNigge
Drives: 17 Camaro LT RS
Unhappy Service Theft Deterrent System - 2017 Camaro LT 3.6L M6
Please help, my Camaro Cluster will not function as normal. I’ve switched to my spare key fob, disconnected the battery for a day, charged the battery for a day (thebattery is 4 months old), and I’m at a loss of options other than buying a new cluster and hoping that fixes the issue. The problem comes and goes; now it's been stuck like this for 5 days, but on day 2 it went back to normal for a day or so. Very strange, not sure what to do or try. The car starts and drives normally, but I’ve been going back and forth to work all week, and I can't tell how much gas I have, which is very annoying. Please help.
Code from ODBII
B3980 - No Environment Identifier Received From Instrument Cluster
BoatNigge is offline   Reply With Quote
Old 02-13-2026, 05:20 AM   #2
Ray3768
Ray3768's Avatar
Drives: 1977 Trans Am, 2024 Camaro 2SS
Don't throw parts at it yet. Here's some info I found for that code:
https://www.autocodes.com/b3980_chevrolet.html
Pull the cluster out and inspect the wire harness. Perhaps simply unplugging and reconnecting the cluster will correct a weak connection.
-Ray
Ray3768 is online now   Reply With Quote
Old 02-13-2026, 11:15 AM   #3
BoatNigge
Praying I fixed it. I learned the BCM is under my steering wheel and I got under there and pushed all the connectors in tight. It came back and is working for now.
Praying that’s all it was.
