![]() Drives: 2016 Camaro SS Join Date: Jan 2016
MAP Sensor Wiring Cooked
Had P0106 and P0107 codes and inspected the MAP sensor.
Didn't expect this! No mods. How could it happen? Will I need to replace the entire harness? Or will be able to get away with unraveling the harness and replacing this section?
2019 Camaro ZL1 6M, Crush
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
The wires look like they were chewed up by mice rather than some kind of heat damage? You might want to check for other chewed wires and damage. You might be able to get a MAP harness extension and splice it on to the cable?
![]() Drives: 2023 SS Join Date: Nov 2025
"meese's peices"
rats! |
