![]() Drives: Camaro 2017 ZL1 Join Date: Nov 2025
2017 ZL1 - Need Verification on SC Bypass Valve Hose Routing (Pic Attached)
Hey guys,
I’m double-checking the supercharger bypass valve connections on my 2017 Camaro ZL1 to ensure everything is in the correct "mode". I want to verify if my current hose routing is set up for the standard factory solenoid-controlled operation or if it has been modified to a vacuum-only setup. I’ve attached a photo of the bypass valve and solenoid area below. Could someone with a stock or properly modded setup take a look and let me know if these connections look correct? I noticed that the valve doesn't move (I think stays closed) when the engine starts. Specifically, I’m looking to confirm: Is the lower port correctly connected to the solenoid? Is the upper port seeing the right vacuum/boost source? Does this look like the factory configuration or has a "bypass mod" been performed? Thanks in advance for the help! |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
That looks correct for the 2017 ZL1. You're good to go unless you are trying to bypass the solenoid Itself.
758 HP/ 804 TQ |
I got confused because many LT4s didn't look like mine. See the attached pictures for 3 cars with the same config. (not like mine though).
