Old 01-09-2026, 11:18 AM   #1
PatrickRodriguz
Drives: 2018 SS
Unhappy 6.1% Fuel in Oil Need Help!
Hi all, I sent an oil sample for testing and after going through all the results (screenshot attached), the only thing that stuck out was getting a 6.1% fuel in oil alert from the report. The car has 126,000km on it, is a second owner, had its first oil change, and I’m not sure how long it sat for. It’s a Canadian car, cold outside temps before sample, 48km trip before the oil sample was taken. Is this common in the LT1? Any advice for people who have experienced similar issues, as I couldn’t find it being reported in the forums?
PatrickRodriguz is offline   Reply With Quote
Old 01-09-2026, 11:27 AM   #2
ctrlz
That sounds very high to me.
I bet you could smell it at 6%.
Any mods to the car?
Might want to compression test the cylinders.
Old 01-09-2026, 04:00 PM   #3
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Since you have no record of oil changes before buying the car, there's a question on how long that oil was in there and what the driving habits were with previous owner.
I'm willing to bet the oil was neglected and seeing how it's a Canada car, the colder weather has a hand in this.
I would send in another sample before it's time for another oil change. See if the results are better. Update us!
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
Dynamical is offline   Reply With Quote
Old 01-09-2026, 05:50 PM   #4
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
Mine was 0.8% after 1500 miles and 5 track hours.
I agree with others. I think the oil was in there awhile and the cold has a little to do with it.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 01-10-2026, 02:03 AM   #5
PatrickRodriguz
Drives: 2018 SS
No mods to the car, good possibility the oil sat in the car for months, if not a year however, the first five years of service history are excellent. The last two years, it drops off.
Old 01-10-2026, 06:31 AM   #6
cdb95z28
cdb95z28's Avatar
Cold temps can play a part, as the engine, especially our DI engines will fire rich until they warm up. Lots of idle time and cold starts can raise fuel content, but I'm not sure how high can the percentage could go in these scenarios.
But dirty injectors can be a major problem. Start with some Chevron Techron (buy the big 32oz from NAPA), Driven Fuel Injection Cleaner, or Redline SI1. These have the highest PEA content.
Second, use only Top Tier fuel. Top Tier has a higher PEA content than the EPA minimum of regular non Top Tier fuel.
Dirty injectors will not atomize the fuel properly. On our DI engines, which by their nature are already hard on oil (fuel dilution), will dilute the oil at a higher rate when the injectors are not properly working.
Regular Top Tier fuel use is more important on DI engines. Especially any of our cars that see the track. Fuel dilution will degrade the viscosity.
https://youtu.be/CAGT5inQScE?si=tjyBvDXohzTPf8pb
https://youtu.be/DAmEGI7xvBw?si=tWplCEgHA2cvCpbQ
https://youtu.be/MAAJCEatYsY?si=3aeUkpGwk6WV-EMZ
"KEEP THE FAITH"-Fbodfather
Old 01-10-2026, 07:14 AM   #7
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Ive replaced a few high pressure pumps on the trucks for fuel in the oil. I usually picked it up by noticing negative fuel trims.
I would replace the pump and the oil then monitor fuel trims to verify the correction on those.
Look at your long term fuem trim, if it's below -5 then you might have the same problem. I wouldn't say jump into changing the pump, reset your fuel trim after your oil change and monitor it over the course of the interval.
Another possible cause would be a lot of cold starts and cold shut downs can cause rich fuel mixture to end up in the oil, i wouldn't think to the extent of 6% but it could be a combination of av few things adding up to that much.
Old Yesterday, 01:30 PM   #8
ctrlz
Originally Posted by bishopts View Post
Look at your long term fuel trim, if it's below -5 then you might have the same problem. I wouldn't say jump into changing the pump, reset your fuel trim after your oil change and monitor it over the course of the interval.
Good idea.
In my book, if you are savvy enough to send your oil for analysis, you will also have a decent scan tool on hand.
It's the same mindset!
fuel in oil, oil contamination
