Old 01-09-2026, 08:34 AM   #1
h3llkittylvr
Drives: 2018 1ss 1le coupe 2022 LT1 RS Conv
Gauge Needle went dark
so I was going to take the beast out the other day, and just like that the speedo gauge needle went dark. the gauge still works as does the tach needle. i tried the dimmer, turning on / off the headlights. but nothing "lights" up the speedo needle. WTH, has anyone had this and resolved?
2018 1SS 1LE 6sp - full mod w. LTx heads, stage 2 cam, LT2, 95mm, 2" long tube, NPP exhaust, E85.. 550+RWP
2022 RS LT1 6sp - Rapid blue w. design spec 3...Wife's car... ZERO mods.
h3llkittylvr is offline   Reply With Quote
Old 01-09-2026, 09:09 AM   #2
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Could be the LED for the needle died. If you're good a fixing things then you could pull the cluster circuit board out test it and replace the LED. Otherwise you're looking at a new cluster.
