Mighty Mouse Wild
How much fluid are you seeing in your CC, and how much vapor are you seeing leaving the CC? I replaced the stock hood rain guard with the Heat Extractor bracket, and light blue smoke is constantly coming out of it. LME says, " That's normal (?).
Anyway, this LME motor has more clearance than the OEM, so it makes sense that it would pass more fluid. It does not consume oil, though.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#2 | |
![]() ![]() ![]() Drives: 2023 ZL1 - All Bolt On's Join Date: Dec 2022
2023 ZL1 A10-Stainless Works 2" Long Tubes & Legend NPP Axle Back•GESI UHO 4.5" CATs•RF BigGulp•Kong 103mm & X-Ported Blower•Griptech 2.30" Upper•ATI Super Damper w/9.45" Lower•THPSI Port Injection w/875cc Injectors•FI Interchillers Stage 2•Brisk RR14S Plugs•Granatelli Malevolent Coils•Katech Low Profile Billet Valve Covers•Katech Duel Fuel Pump•MM Wild 1000HP•DSX Flex Fuel Kit•DSX Billet Lid•DMS 2gal Fender Tank•BMR Cradle Lockout•Weld Solana 18x8 Fronts/17x10 Beadlocks MT ET ST R's•Unlocked TCM•E85=785rwhp/691rwtq +21psi | 1/4=10.5005 @134.21 60ft=1.6182, 1/8=6.8373 @106.11
#3 | |
![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
I feel like it causes more problems than it prevents. If you didn't have constant blue smoke before and now you do, i would think the one thing its supposed to do is not getting done. Also you might have oil in the supercharger. |
#4 | |
#5 | |
But even with a CC, I've pushed out the rear main seal, but it only leaks like 1/4 tsp. a month. It's not worth fixing yet.
2020 ZL1LE A10.
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
#7 |
#8 |
Moderator
Agreed. I have 6 years of supercharger use on my engine, with 4 years of that at 927 to 1066 WHP. Still on the OEM LT1 crank seal (furiously knocking on wood after saying that lol) and I know my tune has had some major ups and downs over the years. Hard to beef with the MM Wild, it just works. Any kind of detonation means that you are probably losing piston ring control leading to crankcase pressure spikes and only the MM Wild will vent that excess pressure off. I’m sure the MM Wild has saved my bacon many times.
#9 |
![]() Drives: 2024 ZL1 M6 Join Date: Sep 2018
The can should be closed during idle and normal vac situations, so no smoke should be visible. If its the Race can that just vents to atmosphere there will be some blow by on a built motor as the ring gaps are set wider than OEM shortblock.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp Kooks 2 inch LT's, Stainless Works Legend NPP THP Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, BMR springs, BMR Cradle lockout, AAD Billet arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
#10 | |
What mechanism would close the can during idle? Vacuum? There's nothing mechanical there.
2020 ZL1LE A10.
#11 | |
I have a Mishimoto that seems to have no problems too. |
#12 |
I think we're mixing vented Vs unvented catch cans. The mighty mouse wild is a very simple arrangement of a vented catch can with a line running off of the rear of each valve Cover up to the 2 inlet bungs on the catch can, unbaffled with a removable filter on the top. It's the type of cc popular amongst people with boosted engines concerned about crank case pressure buildup. It vents continuously to the atmosphere. These are very different from the unvented and probably much more common catch cans that return the fluids to the intake.
2020 ZL1LE A10.
#13 | |
Is it PCV or CCV? |
#14 |
I think that's a fair assessment. In fact, I had a breather as my oil fill cap last year, but I took it out. I suppose the catch can might result in little less mess to cleanup in the engine compartment.
2020 ZL1LE A10.
