Old 01-01-2026, 09:37 PM   #1
Gonzo719
Drives: 2017 Camaro SS
Front subframe
Hello
I was wondering if anyone knows the torque specs for the front subframe to the chassis and the front crossmember brace
Gonzo719 is offline   Reply With Quote
Old 01-02-2026, 09:18 AM   #2
cdb95z28
cdb95z28's Avatar
The bolts called out in orange are 74 lbs/ft.
Note that per the service manual these cradle to body fasteners are one time use, but are NOT torque to yield (TTY) fasteners.
The bolts called out in the red are 37 lbs/ft.
Name:  SUBFRAME BOLTS 2.png
One time use bolts:
Name:  CRADLE BOLTS.jpg
Always verify #s with your VIN.
#12 & #4 are the same. Need four. EDIT: The callout says four needed at location #12...Verify proper amount:
11547921
#3, Need two:
11611261
"KEEP THE FAITH"-Fbodfather
Old 01-02-2026, 10:22 PM   #3
Gonzo719
Awesome thank you
