Old 12-30-2025, 09:25 PM   #1
NG329
Drives: Chevrolet Camaro ZL1 1LE
MCS Coilover Remote Reservoir Mounting
Welp guys,
I have to fall on my sword. I once slammed anyone who replaced the DSSV with other coil over options. Here i am 2 years later and I've reached the limits of the DSSV. I'ver routinely destroyed Front and rear fender liners carrying more than 1.4Gs while running the Pirelli DH slicks.
I am 2.5 seconds off of SCCA race winning lap times on the DSSV. I'm looking at the MCS kit with the remote reservoirs.
Would any one of you running that setup have any recommendations on where to mount those remote reservoirs? Can you post up some pics. I would like to have a game plan before the suspension arrives over the winter. I'll be going with the GTR spring rates.
NG329 is offline   Reply With Quote
Old 12-31-2025, 01:17 PM   #2
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
Not sure how long the hoses are on the MCSs but I mounted my Penske reservoirs in the engine bay in front of the shock tower for the fronts and behind the rear wheel between the fascia and exhaust heat shield for the rears. I used an existing hole in the front and drilled the pinch weld in the rear to mount the brackets.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 01-01-2026, 09:29 PM   #3
NG329
Brilliant! Thank you sir!
What made you go with Penske?
Joe (owner) at Phoenix racing offered to do a custom Penske setup for me but that would be just shy of $10k. His son Andrew is 15 time SCCA champion. I've been debating if I should do that or get into the MCS and save the $3000.
Old 01-02-2026, 05:48 AM   #4
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Check out this thread https://www.camaro6.com/forums/showt...=624621&page=4
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 01-02-2026, 01:39 PM   #5
Scargoes
Scargoes's Avatar
After seeing what my friend went through with dealing with his MCS supplier and then the hassle he had getting the dampers rebuilt, I decided to go with a guy local to me that I also race with. He builds, rebuilds, and tunes Penskes as a side job. And many of the national champs in the region use him for suspension work. It was quite a bit more expensive but knowing I have someone I can call on a moments notice to help me out is quite reassuring.
If I were to do it again, I probably wouldn't go the 3 way route, but I would go with Penske again. If you can swing it, going with someone close to you who can make changes and dyno the dampers is worth it.
Old 01-04-2026, 01:25 AM   #6
NG329
Originally Posted by carguy55 View Post
Awesome! Thank you sir.
Old 01-04-2026, 01:33 AM   #7
NG329
Man, I had not considered that. Funny enough, Penske is not too far from me and I had them rebuild a motorcycle shock in the not too distant past. They turned it around within a week's time. I had assumed MCS would be similar, but I guess not.
I guess if I did go the Penske route, I would have Phoenix behind me for support and we often attend the same Open Track events where they're testing customer builds.
I was thinking 2-way (double) adjustable with remote reservoir. I could see myself getting lost with all the extra adjustability of the triple.
Based on what I'm hearing it seems like Penske is the more logical choice, taking long term support in mind. ...I guess the question now is, how important to me is that initial $2,000-$3,000 in price difference.
Old 01-04-2026, 06:34 PM   #8
Scargoes
Scargoes's Avatar
It was just over 2 weeks for his rebuild through MCS. But that was after 2 weeks of searching for someone closer to rebuild them and being told no. He does seemingly have the bastard child of their dampers, the 2 way non reservoir. He could not find anyone but MCS that would touch them.
As far as things I'd do differently, I'd try to get a set of StanceParts air cups for the front so I can get the front end up for driveways. Being an inverted design, the Penske struts have the reservoir hose out through the top shock shaft and adding the cups would require the system to be opened up and then rebleed when its all back together again. Not hard if you have the tools and nitrogen, I don't.
Old 01-04-2026, 08:07 PM   #9
NG329
Those AirCups look pretty good actually. I would be concerned that they'd malfunction tho. Just my luck. lol
2 weeks for a rebuild is not terrible..... and I guess that remote reservoirs are easier to service. I'm going to reach out to Phoenix this week and see what their turnaround times are, as well as the time they'll need to have my car.
I'm one of those guys that love to save money when I can, but I'm also willing to pay for convenience, ..... or simply pay to avoid inconveniences. ...if that makes any sense.
Old 01-05-2026, 02:10 PM   #10
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
I dont have photos anymore but this was a video i made on my camaro last winter with shaftorks coilovers. you can see where i put the res there
#53 F Street
2025 FS National Champion
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 01-05-2026, 06:22 PM   #11
almimono
Drives: 2010 camaro ss, 2024 Chevy Camaro 2
Welp guys,
For the MCS remote reservoirs, most people mount them up high in the wheel well or along the inner fender area. just make sure they’re clear of suspension travel and heat. Plenty of pics in the MCS install thread if you search for ‘remote reservoir location.’ Works great with GTR spring rates.
almimono is offline   Reply With Quote
