![]() Drives: Chevy camaro zl1 Join Date: Oct 2024
My 2018 camaro oil pump went out....need a good shop for replacement
My 2018 camaro zl1 oil pump took a crap on me I need a good shop with a reasonable price to get it repaired and yes I know its pricey. I stay in the dfw area closer to mansfield. Does anybody have any suggestions?
#2 | |
![]() ![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
A friend of mine works in Arlington. He recently changed shops so i dont remember the name of it. I will call him tomorrow. He is probably the only tech ive worked with that i will without a doubt say is better than i am. Last edited by bishopts; 12-28-2025 at 11:36 PM. |
Actually the code for the valve being stuck open came up the a few days later there was 0 psi and it said turn off immediately
#4 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
If you are willing to drive to Austin, I can highly recommend Exodus Performance. Let me know if you need an introduction.
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
Ive been seeing P06DE codes on GM vehicles a whole lot. LTG and LKW mostly and those have solenoids that are separate from the pump, but i wouldn't be surprised if it's the same pressure contol solenoid across the board. I had a wrangler in the other day with the same failure but that one needed the pump because the solenoid wasnt sold separately.
If you have the ability to look at live data then you could see both pressure, before and after the regulator. That would be a good info to have to determine if it was safe to drive or if it needs to be towed. |
Labor is 18.2 hrs. But that was using my VIN which is for an SS.
The solenoid isn't sold separately from GM but the oil pump really isn't very expensive. $164 is my cost i would guess you will end up paying about $280 for the pump. |
#7 |
call GSPEED to see if they can do it or recommend a place 877-512-5180. They're at MSRC
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87 |
#8 |
Brian Crawford Automotive in Arlington
817 303 6200 Ive never delt with the shop but i know the tech very well. If anyone would ever be allowed to work on my car it would be him. Shelby is his name. |
| Tags |
| camaro, chevrolet camaro, oil pump, zl1 |
