Old 12-21-2025, 01:21 AM   #1
buckwam
Drives: 2021 camaro 1ls
check your catch can
I installed a mishimoto catch can set this summer and had very little to empty in the warmer months, but yesterday I checked and one was full. I guess the colder weather is to blame.
buckwam is offline   Reply With Quote
Old 12-22-2025, 05:34 PM   #2
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Thank you for the reminder
Old 12-22-2025, 11:25 PM   #3
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
it must be the moisture in the air. The catch can on my LTG has filled twice with water with a couple drops of oil. My LT1 doesn't do this. I was freaking out. But it's plain water, not coolant or anything else.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 12-23-2025, 11:22 AM   #4
ctrlz
Catch can is cold and condensing water vapor. Water is both in the air and a byproduct of combustion. There will be some blow-by in the crankcase.
Old 12-23-2025, 12:05 PM   #5
bishopts
bishopts's Avatar
Looks like I've got a little moisture in mine.
Old 12-23-2025, 12:18 PM   #6
DeuceCam
Drives: LT1
Yeah this can happen in cold weather. Short drives--when engine doesn't reach operating temp--and catch can location--if it's in a spot where it's not exposed to engine bay radiant heat--will exacerbate the issue. The catch can lines can also get clogged with congealed oil/water vapor.
This is why air/oil separators often have a coolant circuit, to keep the can warm.
DeuceCam is offline   Reply With Quote
Old 12-23-2025, 12:33 PM   #7
bishopts
bishopts's Avatar
I'm running with my pcv blocked off and only ccv is open. So that's probably not helping.
Old 12-23-2025, 12:46 PM   #8
bishopts
bishopts's Avatar
This pcv path bypasses all but mishimoto catch cans. So i just ran a old head bolt from a gm 2.4 into the port to block it off. Its been working fine and i noticed it doesn't smoke at idle anymore.
