![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Feb 2025
ZL1 1LE - Max Front Camber with OEM (DSSV) Setup?
What is the maximum front camber possible with the OEM setup (Multimatic DSSV)?
Last week, a well qualified alignment shop aligned my car and then told me the max front camber they could get is "3.2" (both sides). Another racer at the track told me it's possible to get 3.5 (or more) but there's some fastener that needs to be lossened - ? I want 3.4 to 3.5 because I track my car hard and it understeers at the limit. Also, if 3.2 is the max I would appreciate suggestions of mods necessary to get more camber. |
Who Needs to KNOW?
Yeah, i think mine is closer to -3.5 range. There is adjustment on top and at clevice. Don't recall if there is cam bolt but i know there is location for jack screw.
Although last alignment sheet i can find notes setting of -3.0
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Lots of info here on the forums concerning adjusting front camber...beyond what camber plates will do. Here's just a few threads:
https://www.camaro6.com/forums/showthread.php?t=609290 https://www.camaro6.com/forums/showthread.php?t=558904 https://www.camaro6.com/forums/showthread.php?t=560773
"KEEP THE FAITH"-Fbodfather |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
Damn. 3 degrees of camber. That must look wild from a visual standpoint!
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ |
Who Needs to KNOW?
stock wheels are so wide that even at -3, it fits nice, almost better than as delivered camber where top of tire sticks out quite a bit.
![]() Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
If you slot the top spindle hole a bit more with a debur bit, i.e. the top hole that bolts through the spindle, you can easily get more camber. It takes very little to make a big difference. I'd start at about 0.040 or 0.050 and measure. I went more and wound up with over -4!!!
Its not a big deal though. Just make sure the spindle bolts are properly torqued. Mine held -3.4 fine. |
