17s for a drag radial
Hey yall, looking to buy a set of 17s for a drag pack on my camaro on the cheap side, I've heard that racestars fit over the brembo brakes, but i wanted to be certain before I put an order in. Any help or advice would be appreciated.
Moderator
17’s will typically fit over the rear SS brakes with no problem. Sorry I can’t confirm Racestar although I’m sure someone else can chime in. I ran 17” Forgestar with no issues at all.
I run Weld 17s over SS Brembos, no problem.
Camaro SS - (almost) FBO/E85: Tuned by Snackbar Tuning/21st Century Muscle Cars
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
I had 17” VMS on mine for quite some time before I let them go. Check my journal on tire sizes you want to run in the front without running across any ABS issues
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
Thanks yall
![]() Drives: 2018 SS 2 Join Date: May 2025
Let’s see more pics of truck, please.
