Old 12-11-2025, 08:53 PM   #1
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
2.5 swap
This is the side by side comparison of the 2.5 non turbo and the 2.0 turbo block. Im going to tear down this 2.5 and rebuild it with a 2.0t head. Ive just got to drill out the turbo oil and coolant flange areas.
The 2.5 is from a malibu that blew the head gasket.
The 2.0 is from an ATS that was smoking but ran fine.
They were both going to the scrap so i figured why not have some fun with it. If i get it all sorted out then i will put it in my ATS. Most anything i learn and share from it should carry over to the camaro 2.0.
Old 12-12-2025, 12:18 PM   #2
bishopts
bishopts's Avatar
In theory I'm increasing displacement by 25%, so horsepower should increase pretty much the same as long as the boost pressure stays consistent.
So 275hp to 346hp.
Old 12-17-2025, 10:59 AM   #3
bishopts
bishopts's Avatar
I have never taken the LKW engine apart before. I was pretty sure it's the same basic design as the LTG but i wasn't sure if they made them open deck for cooling reasons. Luckily it's a closed deck block.
Old 12-17-2025, 11:42 AM   #4
bishopts
bishopts's Avatar
Verified all the same oil and coolant passeges are here between the LTG and LKW.
The stroke definitely bigger. It's pretty much going to be a LTG with a stroker kit. I didn't realize that the saleen S1 runs this same setup. 450hp 400lbft. Im pretty sure there is more to that engine than this one.
Old 12-17-2025, 05:18 PM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
So 275hp to 346hp.
So there’s definitely more to that but understand your premise. Your turbo can’t magically produce 25% more airflow without getting outside its efficiency island so IATs can get out of hand if so. What usually happens in situations like this is the engine becomes more of a torque monster in the mid range and you make similar horsepower numbers up top.
Now I admittedly don’t know anything about the 4 cylinder turbo and its size so maybe there’s more headroom available than I know about. But it’s always fun to talk theory.
Joshinator99 is online now   Reply With Quote
Old 12-17-2025, 06:45 PM   #6
bishopts
bishopts's Avatar
I was explaining that to a coworker today. I'm going to try and see how the stock turbo does but i have a feeling the volume will start falling off at higher RPM for sure.
Old 12-17-2025, 11:48 PM   #7
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
How different are the blocks? Can't the 2.5 crank be put into the LTG? The have the same 86mm bore, correct?
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 12-18-2025, 03:31 PM   #8
bishopts
bishopts's Avatar
The bore is 88mm vs 86mm.
The crank and rods could be put into the LTG and use LTG pistons. Or bore the sleeves and use the LKW parts.
The LTG is 9.5:1
The LKW is 11.3:1
I was going to measure the head gaskets to see if the LTG uses a thicker head gasket to lower compression, but i couldn't go to work today because my son is sick.
It could potentially make more power on less boost, or it can shatter the connecting rods. No one really knows i guess.
Old 12-19-2025, 10:22 AM   #9
bishopts
bishopts's Avatar
One of my favorite things about ecotec engines is how they build the bracing for the crank. Its annoying to take off but it makes all the caps and block work together.
Old 12-19-2025, 10:23 AM   #10
bishopts
bishopts's Avatar
Fractured powdered metal rods and a forged crank.
Old 12-19-2025, 09:34 PM   #11
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
I love this kind of thing. Definitely a fun idea for sharts and giggles.
Will be watching your progress and definitely curious how this turns out!
speedyink1 is offline   Reply With Quote
Old 12-22-2025, 03:45 PM   #12
bishopts
bishopts's Avatar
This is an odd hole to try and drill. It's pretty deep and for some reason it's threaded close to the surface.
I'm going to go ahead and move to pulling the LTG block down and send it i get the cylinders bored to 88mm
Old 02-17-2026, 06:19 PM   #13
bishopts
bishopts's Avatar
Its been on the back burner for a few months but i finally took the block to the machine shop.
For all you girls that complain you can't fit your golf clubs in the trunk, i put an engine block in mine.
Old 02-17-2026, 06:54 PM   #14
beowulf556
Drives: Camaro SS 1LE M6
Hahaha. Rear engine Camaro!
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
