![]() Drives: 2020 Rally Green Metallic 1SS 1LE Join Date: May 2021
For Sale: 3 sets of used Apex track wheels
18s:
- SM-10 18x11 Front 18x12 Rear. Camaro fitment ZLE offset, no spacers required. Satin black, in very good condition. Only used for one set of tires, no TPMS. $1,250 19s Both of the following are the same specs: 19x10.5 ET22 BMW fitment. Used on an SS 1LE factory suspension with strut grind/5mm spacer up front running square setup. - EC-7 anthracite-3 wheels used, one new in box, no TPMS, needs tires. Sold - SM-10 satin black with TPMS. Set of 295 Michelin scrubs from the Mustang Challenge series installed, but not used since received. Ready to track $1,800 Located near I-77/I-81 intersection in southwest Virginia, around an hour from Bristol, TN. Last edited by jones1090; 02-27-2026 at 11:58 AM. |
![]() Drives: '21 M6 1SS 1LE Join Date: Aug 2021
Do any of them work with factory SS 1LE suspension and no modifications / wonky offset?
Fitment
I used them on factory SS 1LE suspension. As noted in description I ran the 19s following a strut grind, 5mm front spacer. The 18s were used with no spacers. Beyond what I used and know fit, a search of the forum can provide much more info.
EC7s Sold.
2020 RGM SS 1LE
