Old 11-25-2025, 01:16 AM   #1
Mr Monte
Mr Monte's Avatar
Drives: 2023 Camaro 2SS Convertible
Color matched ZL1 brake upgrade on SS
My 2023 2SS came with the red Brembo brake upgrade. I sold them for $1,000 and installed new leftover ZL1 brakes that I painted rapid blue.
Will bleed the brakes tomorrow then put the ZL1 wheels back on.
Before & after picks.
It's nice to have options.
Mr Monte is offline   Reply With Quote
Old 11-25-2025, 09:39 AM   #2
SWFLZL1
Drives: 2022 ZL1
Looks great!
2022 ZL1 M6 Coupe
SWFLZL1 is offline   Reply With Quote
Old 11-25-2025, 05:44 PM   #3
His ZL1
His ZL1's Avatar
Drives: 92 B4C, 21 1LE, 24 2SS
I'm curious what paint you used? I checked out G2 and they say they can match the yellow on my car. The match for your blue is good.
His ZL1 is offline   Reply With Quote
Old 11-25-2025, 06:07 PM   #4
Justcruising
Justcruising's Avatar
Drives: 2019 Chevrolet Camaro 2SS A10
Looks awesome
2019 Camaro 2SS A10 Procharged, Flexfuel, with Stainless Works headers back to Legend series mufflers.
Justcruising is offline   Reply With Quote
Old 11-25-2025, 06:13 PM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Really nice work!
Old 11-25-2025, 10:57 PM   #6
Mr Monte
Mr Monte's Avatar
All back together. Very happy with the results. Next is a full detail, paint correction, add rally strips then ceramic coat.
Old 11-25-2025, 11:40 PM   #7
Mr Monte
Mr Monte's Avatar
I ordered a pint of rapid blue base & clear. Used high temp primer, sprayed the base color, added decal then sprayed 2K clear. I have 80K miles on a set of Brembos I did awhile back and still look like new.
Old 11-26-2025, 04:25 PM   #8
His ZL1
His ZL1's Avatar
Thanks for the info. So paint other than primer is not hi-temp? The brakes are not likely to see the temperatures reached in a competition environment? Not likely mine will either.
One concern with doing mine is the red was ceramic coated. I guess a good cleaning and sanding of the surface, assuming I can reach them all, should take care of that.
Old 11-26-2025, 08:52 PM   #9
Mr Monte
Mr Monte's Avatar
Correct, only primer was hi temp. A good cleaning & sanding will remove the ceramic coating.
