Old 11-17-2025, 08:47 PM   #1
2020maro
Drives: Camaro SS 1999&2020
Oil pan leak replacement of oil silicone gasket
Took my 2021 ss Camaro to the shop today to get a diagnostics on this slow oil leak I’ve been having for quite a while. Turns out there’s a hole in oil pan and they need to replace the oil resistance RTV silicone gasket has this happened to anybody else labor is $185.00 an hour for 11 hours and the part is only $12.88 for two of them so it’s $25 for that so in total $2063.51 for labor and parts here in california…
2020maro is offline   Reply With Quote
Old 11-17-2025, 08:58 PM   #2
beowulf556
Drives: Camaro SS 1LE M6
Holy shit.
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is online now   Reply With Quote
Old 11-17-2025, 09:19 PM   #3
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
So there is a hole in the oil pan? Or the silicone gasket is leaking?
Old 11-17-2025, 09:24 PM   #4
2020maro
the silicone gasket is leaking …. i’m just a girl 😭😭
Old 11-17-2025, 09:52 PM   #5
bishopts
bishopts's Avatar
The labor is high because you have to lift the engine or drop the subframe or a combination of both, just to get the oil pan off to reseal it.
Old 11-17-2025, 10:10 PM   #6
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
A 2021 Camaro may still still be covered by the 5 year powertrain warranty? The repair should be free?
Did they check for loose bolts? Some people have been able to resolve an oil pan leak by simply tightening the bolts to factory specs.
Old 11-18-2025, 01:11 AM   #7
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
THIS!!! Check your warranty and oil pan bolts...
Old 11-18-2025, 01:04 PM   #8
Deadpool Z
Deadpool Z's Avatar
Drives: Chevrolet ZL1
Check the oil pan bolts. When I had my oil pump replaced on my ZL1, my buddy (former GM Master Tech) found that half the bolts were loose and oil was leaking. My buddy said it was pretty common on the LT1 and LT4's for the oil pan bolts to come loose.
I never had a drop of oil reach my garage floor, so I never knew it was leaking!
Deadpool Z is offline   Reply With Quote
Old 11-19-2025, 03:16 AM   #9
2020maro
i just hit my 5 year…. 50,000 miles i plan to call the dealership tomorrow and figure out my warranty left
Old 11-19-2025, 07:33 AM   #10
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
You can get the exact date/mileage your VIN warranty will end here.
https://experience.gm.com/ownercenter/recalls
My car developed an oil leak a few years ago which I thought was from a past oil change, turns out the oil cooler and front timing cover were both leaking. Covered under warranty but the breakdown I spotted while there was $2122.19 parts + $866.98 labor for a total of near $3k
2016 1LT v6
- Totaled
Happiness: Infinite
Old 11-19-2025, 08:19 AM   #11
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Second a few loose bolts on my LT1 fixed it's little drip and I was able to do it myself.
