Old 11-14-2025, 01:43 PM   #1
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Who has the best Rear Seat Delete Kit?
Hey everyone...
I am in need of a Rear Seat Delete kit for my ZLE and another one, I am building that is also getting the StudioRSR rear cage assembly installed into next month when it arrives.
I will most likely add some expandable foam to the rear seat cavities to offer some structure to the panel base as well as insulate noise/heat from the driver's area.
I know StudioRSR makes a kit, but at an additional $1200... ouch! (Insert ET sound here!)
Patriot Motorsports USA is offline   Reply With Quote
Old 11-14-2025, 01:59 PM   #2
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Beast Build
Not sure this is what your looking for. But this is the one I installed:
https://www.camaro6.com/forums/showt...611982&page=39
Got to post #539
Hope it helps!
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 11-14-2025, 02:14 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’ve got the Shrader RSD in mine. It’s nothing fancy…hard to believe it’s almost $400 lol… But it looks fine back there.
https://www.shrader-designs.com/prod...o-seat-delete/
Joshinator99 is online now   Reply With Quote
Old 11-14-2025, 05:22 PM   #4
Tay
Drives: 1985 Oldsmobuick
Originally Posted by Patriot Motorsports USA View Post
Hey everyone...
David,
Be cautious with the StudioRSR cage. They do not have the best track recored and are known to have issues.
Trackspec Motorsports makes the best bolt-in cage for the 6th gens in my opinion. Theirs is the one I will be going with.
https://trackspecmotorsports.com/col...lt-in-roll-bar
They make a weld-in cage as well.
https://trackspecmotorsports.com/col...t-2016-present
Tay is offline   Reply With Quote
Old 11-14-2025, 05:31 PM   #5
S.Macias
Monterey County Camaros
S.Macias's Avatar
Drives: 2016 Camaro V6 1LT
Went with a StudioRSR cage as well. Already had the Shrader rear seat delete. Easy enough to trim a bit to fit. Definitely cheaper than the pre-cut ones that run $900+. Shrader may be running a Black Friday sale…
Instagram: @smaciasracing
S.Macias is offline   Reply With Quote
Old 11-15-2025, 10:58 AM   #6
SpartanSS
Drives: 2023 Camaro 2SS
This one’s pretty nice too…haven’t seen it on anyone’s car here though
https://www.forgedfinesse.com/en/pro...-gen-v6-v8-zl1
SpartanSS is offline   Reply With Quote
Old 11-15-2025, 04:19 PM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
I really like my Schrader performance rear seat delete
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 11-24-2025, 07:29 AM   #8
ZL1_1LE
Drives: Camaro ZL1
I do as well, but I put the rear seats back in after the long tube install to quiet it down some in the cabin at lower RPMs. Anyone put sound deadening "paper" back there, and did it help any?
ZL1_1LE is offline   Reply With Quote
roll cage, seat delete, zle
