Stanadyne Goliath high pressure fuel pump!?
My new build has forced me to look for the next step up in fuel delivery and I always assumed it was going to be this pump. However, a brief investigation on the web indicates that this pump has experienced some serious problems.
Is there another high pressure fuel pump that would satisfy my needs or must I go to one of the port injections?
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#2 | |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Do you have the option for Katech Dual Pump, DSX Aux and Port injection?
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Yeah I think so. I've got the DSX low side and my intake runners have the bungs for port injection. So I could probably make it work.
2020 ZL1LE A10.
#4 | |
Moderator
Honestly, you should just bite the bullet and do port injection at this point. I kicked the can down the road for years and felt like I was always struggling to get enough fuel into the motor.
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
I run the XDI version of the Goliath which I believe may be the most recent iteration of it. The problem with them was that a lot of people were installing it by just sending one side of the bolts all the way home and then tightening the other side (which is an absolute no no anyways and should be common sense but here we are) so the springs were sitting in there all cocked which would ruin them, and by ruin I mean breaking of the smaller secondary spring. That and these set ups are a little more sensitive on install compared to the LT4 HPFP. It's really made for folks who run 32% fuel lobes on their cam set ups and I believe that may have been confirmed by Stanadyne themselves if I remember correctly. Anything more than that and you will run into issues. So if you have a 38 or a 42% lobe you're out of the running for one of these.
I've been beating the shit out of it since I installed it without a single problem. So much so, that I no longer see the need in keeping my old LT4 HPFP as a backup. The only caveat is that it is louder than the LT4 pump so expect some added fuel pump noise in the engine bay. It is what it is.
758 HP/ 804 TQ Last edited by ZLRob; 11-14-2025 at 08:43 AM. |
#6 | |
2020 ZL1LE A10.
#7 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I think the Goliath issues were (a) a bad batch that was recalled and (b) user error. I confirmed mine was not in the bad batch with XDI.
I can also say you need to be very careful in how you install this. You can't just drop it in. Preload and max travel are important. You have to know your numbers. See my build thread. Granted, I havent started the car yet. But I can see how people get into trouble with this pump.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#8 | ||
Super Stock
758 HP/ 804 TQ |
#9 | |
fo'shizZL1
What didn't Stanadyne like about the 38% lobe? Max travel? My pump compresses about 10mm and I'm only using about 8mm of travel. I wasn't concerned, but now I'm very curious as to what Stanadyne had to say. See posts 144 and 145 for my notes: https://www.camaro6.com/forums/showt...632809&page=11
#10 | |
Super Stock
I may be entirely off kilter here and may be prefacing what I'm saying based on the fact that my set up didn't require a lash cap or anything special to run it. It was essentially a plug and play set up just like the LT4 pump was after my cam install. If I do remember right there was an issue with overall mm of travel with set ups larger than 32% but if you are running one on yours with a 38%.. oh wait, you said you haven't started yours up yet huh? That'll be the x factor here, but if you measured it out and it set up okay then obviously you turned over the engine a few times to confirm binding wasn't present, I trust that it should work just fine without a hitch. Edit: I just read over your notes. Very interesting stuff! You did require modification to the valley or other items to make it work though correct?
758 HP/ 804 TQ Last edited by ZLRob; 11-14-2025 at 10:10 AM. |
#11 | |
fo'shizZL1
Ok, this makes sense. Thanks for the additional info. Yeah, from my perspective the keys are: ensure there is preload, ensure you measure a ton, and don't use a lash cap on the Goliath since it doesn't fit. If you have preload, and you know the max travel still has 0.030"+ , then I think it should be fine. My opinion only, of course. We'll see how mine works once it's running.
#12 | |
Super Stock
Without saying this offensively because there is absolutely none intended Rob I gotta say that their base instructions and the pump itself are really designed for folks who are looking for a plug and play solution with minimal set up required for it to run. Of course anything can work with enough money and resources or access to, but your set up is definitely extracurricular and required additional outsourcing to make it allow for functionality. It's basically an LT4 pump with additional modifications to allow for increased volume and flow output designed by the very manufacturer who built the pumps for GM in the first place. That's just the way they made it. Again, I say this with no intent to offend, and I'm glad to see that it can be configured with enough time to allow for it to run. Great job by the way! Let us or even me know when you fire it up and whether or not it was a fruitful venture, though I assume it will indeed be fruitful based on your findings.
758 HP/ 804 TQ Last edited by ZLRob; 11-14-2025 at 10:44 AM. |
#13 |
On race gas a LPE big Bore & +50 injectors should support 1100+whp. +65's would likely support 1250-1300.
Moral of the story, I think you will need the LPE pump and larger injectors. Or go Port as Josh mentioned. I don't have any experience with the Goliath pump, but that is interesting to know they don't like 38% lobes. But I do know some shops have been moving back to 32% lobes for longevity purposes regardless of the high side pump type.
#14 | |
Super Stock
758 HP/ 804 TQ |
