Old 11-04-2025, 08:07 PM   #1
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
Want new ZL1/1LE calipers
Can someone share the part numbers for the copper free BCD Front and rear Calipers in Red for ZL1/ 1LE 2022-2024
I have 2 different part numbers for both Front and rear
and am not sure which to get
Front Calipers
LH 84229190
RH 84229191
Rear Calipers
LH 84212289
RH 84212290
And also
Front Calipers
86791549
86791548
Rear Calipers
85113991
85113992
My ZL1 already has copper free in grey and would like the Red with the 1LE logo
ZL1/1LE Convertible Clone
IMCWORTH is offline   Reply With Quote
Old 11-05-2025, 02:48 AM   #2
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
I’d just get the ones you have now powder coated. It’s way cheaper than buying new calipers, and a good shop can add the 1LE logo so they’ll look just like the factory red ones.
https://www.instagram.com/p/Cb1J4J0u...oxMnU5N2QzYQ==
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 11-05-2025, 06:19 AM   #3
ZL1_1LE
Drives: Camaro ZL1
Front Calipers
LH 84229190
RH 84229191
Rear Calipers
LH 84212289
RH 84212290
And also
Front Calipers
86791549
86791548
Rear Calipers
85113991
85113992
Why do they have to be copper free? And I thought you sold that thing, glad you ended up keeping it!
ZL1_1LE is offline   Reply With Quote
Old 11-05-2025, 06:28 AM   #4
Smokin19
Drives: 19' ZL1 A10, w/pdr
I powder coated mine in red with the ZL1 emblem.
Smokin19 is offline   Reply With Quote
Old 11-05-2025, 06:29 AM   #5
swisstyphoon
I think it’s more about the brake pads, not the calipers. CA and WA require copper-free pads for environmental reasons, the calipers should be the same.
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 11-05-2025, 06:30 AM   #6
ZL1_1LE
Drives: Camaro ZL1
Those look great man! You have a video on how you did it?
Old 11-05-2025, 06:34 AM   #7
Smokin19
They were completely disassembled, coated, all new internals and new fluid. No video pretty straightforward if you are a mechanic.
Old 11-05-2025, 08:14 AM   #8
cdb95z28
cdb95z28's Avatar
Calipers are not the same. While the rears are spot on for the non BCD ZL1/ZLE rears, there is a change that warrants a new part #.
The biggest change with the BCD components is the much larger 398mm front rotor. The rear rotor is also visually similar to the rear non BCD ZL1 rotor but it also has a different part # due to a different coating.
It is not just a brake pad change.
"KEEP THE FAITH"-Fbodfather
Old 11-05-2025, 08:17 AM   #9
cdb95z28
cdb95z28's Avatar
There were leftover from production Gen6 calipers of various variants, ZLE included, on Ebay earlier this summer. BCD and non BCD.
Schram Auto. But their shipping practices suck bad. I had to return a couple due to shipping damage.
Old 11-05-2025, 09:15 AM   #10
IMCWORTH
IMCWORTH's Avatar
Copper free are larger brake rotors and thats what I have so the caliper is also larger
I did end up keeping it for now. when It sits there in the garage I want to sell it then I get behind the wheel and think NAW! I'll keep it for a while longer
Old 11-05-2025, 11:07 AM   #11
IMCWORTH
IMCWORTH's Avatar
I've been pricing it out between powder coating each caliper and then new seals it's not that much of a difference. It's a couple hundred bucks. Then I have the hassle of taking it to the place to powder coat waiting a couple days and then hoping they do it right. it just seems so easy to buy new ones.
i just need the right part numbers
Old 11-06-2025, 08:42 PM   #12
nikerret
Drives: 2014 Ford F-350
Front right (passenger side) BCD caliper on one of the last 2024 SS1LE’s built.
It’s not a number on your list, so I’m not sure it’s helpful. I couldn’t get the front left. If you need it, I can pull the wheel and look.
2024 Red Hot 2SS 1LE w/BCD, PDR
2014 F-350 Crew Cab Cassis Cab Dually 6.2L w/4.30
2014 Hyundai Elantra GT
1995 Buick Roadmaster Estate
nikerret is offline   Reply With Quote
Old 11-06-2025, 09:30 PM   #13
IMCWORTH
IMCWORTH's Avatar
That number doesn't come up with anything that I could find
Old 11-07-2025, 05:58 AM   #14
cdb95z28
cdb95z28's Avatar
Those #s are to ID an entire assembly during vehicle production.
