Electrical Engineer
Non-Bose Factory EQ signal
Measured the factory signal in my 2023 SS non-Bose. Pretty hideous. This was measured with the configuration shown, this is the electrical signal to the speakers (not using a mic). This is a different, more detailed measurement than I shared before.
Correction takes several forms. A Kicker KeyLoc is the most affordable and easiest solution.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 45k mi. @ Mar 2025 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
can you elaborate on the process here?
I assume frequency sweep signal. But abbreviations "LL" and "RL"... I thought your system had 4 outputs: Front left and right, rear left and right. |
