Old 11-02-2025, 12:15 PM   #1
redfish86
Drives: GMC Sierra
Finally got the cage, seats, and harnesses in
Man, that was an adventure.
The CMS cage was relatively straightforward and easy.
The seats? Not so much.
Started with Sparco bases but a couple things bugged me about them. The inboard position to install the T-50 bolt to secure it to the car doesn’t allow for the stock bolt, the bolt is longer then the available space in between the actual seat base and the tab which screws to the car. I’ve seen where some folks drilled out the plate above but I didn’t love that idea. Additionally, there is no where to mount the sub straps for the harnesses and I didn’t particularly want to drill holes in the floor of the car.
I ordered Brey Krause seat bases and the accompanying sub strap mounting bar. Some minor mods still had to take place to the OMP side mounts but it eventually all worked out.
OMP HTE-R (xl on drivers side, regular on PAX side), Schroth 6 point, CMS roll bar, and as mentioned, OMP side brackets and Brey Krause mounts.
I may wind up pulling the drivers side and moving it up slightly after this months trip to Barber, it’s hard to tell just driving around the roads if I have it just right.
redfish86 is offline   Reply With Quote
Old 11-02-2025, 05:31 PM   #2
Baddawg53
Drives: 17 hyper blue 2SS M6
Looks great!! I went with the Brey Kraus also based on reviews I had read on this forum. Not super simple but they work well. Love the red belts too. Nice work!
Baddawg53 is offline   Reply With Quote
Old 11-03-2025, 10:48 AM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
looks good my buddy has them in his ss also they are super deep seats and pretty damn comfy!
Old 11-04-2025, 07:05 PM   #4
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
Great choice on the seat.
That1guy_tim is offline   Reply With Quote
Old 11-04-2025, 08:14 PM   #5
redfish86
Drives: GMC Sierra
What did y’all do with your FHR when making the switch to harnesses? I’m pretty comfortable with my Hybrid S. Any reason to switch to a “regular” HANS type device?
Old 11-04-2025, 11:11 PM   #6
Baddawg53
I went straight from nothing to a Hans device, I can't imagine you'd need to get rid of the Simpson if you like it, can't say I've ever read that it was required for a typical Hans.
Old 11-04-2025, 11:40 PM   #7
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Bravo! Well done!... Whats the weight savings on those seats?
Old 11-05-2025, 08:46 AM   #8
redfish86
Drives: GMC Sierra
I didn’t weigh anything but I suspect by the time you add the cage it’s a zero sum game
Old 11-06-2025, 01:04 PM   #9
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Be sure to stow the belts before closing the doors!!! The metal inserts have a way of finding the door sills!!
Patriot Motorsports USA is offline   Reply With Quote
Old 11-06-2025, 08:44 PM   #10
redfish86
Drives: GMC Sierra
Thx! Stock belts are red so I tried to keep that theme going!
Old 11-19-2025, 09:16 PM   #11
Olemiss540
Drives: 2018 Camaro ZL1
Looks great!
Olemiss540 is offline   Reply With Quote
Old 11-20-2025, 05:55 AM   #12
redfish86
Drives: GMC Sierra
Ran at Barber last weekend, man what a difference. I could definitely feel the car much better and much less fatigued at the end of the weekend.
