Old 11-02-2025, 08:14 AM   #1
ukester
Drives: 2016 z06
zl1 1le wheel dollys?
since the rear tires are over 12 inches does anyone use wheel dollies and which ones do you use?
Thanks
Mark
ukester is offline   Reply With Quote
Old 11-02-2025, 11:19 AM   #2
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I picked up a set of these to move the car around while I'm rebuilding it. 15" wide dollies.
https://www.amazon.com/4-10000LBS-Ca.../dp/B0DY7FRFM8
Fit my ZLE-sized wheels with no issue.
https://www.camaro6.com/forums/showp...6&postcount=36
Mods being installed-
Old 11-02-2025, 11:30 AM   #3
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
Thanks
Mark
I have used the ones from Harbor Freight and put a thick piece of cardboard between the tire and the lever used to pump it up. I use these at times to get a jack under the car as well.
If you buy four dollies and the stand, the price of the package is lowered $140.00 in our region.
https://www.harborfreight.com/automo...lly-64601.html
Patriot Motorsports USA is offline   Reply With Quote
Old 11-02-2025, 12:03 PM   #4
ukester
Drives: 2016 z06
so the harbor freight will accommodate a 13 inch tire?
